Results 1 to 4 of 4
Thread: newbie with a64 2800 and neo platinum. help
    Jul 2004
    hey, first off i wanna say great forum, this is my first time here and i love it. I have been reading alot on here and i have a couple questions before i overclock
    i have this system that i have to put together (waiting for my video card to arrive)
    athlon 64 2800
    msi k8n neo platinum
    512 corsair value select ddr 400
    ATI 9600XT all in wonder
    my questions are:
    1. I am new to overclocking, what settings do i mess with in the bios of the neo board, i cant afford to burn the cpu or board so what should set and to how much, i dont mind taking baby steps to get where my system can handle it (any help with this would be great, like i said i am new so when i am setting the volts i dont know how much to set, and for what)
    2. What fan should i buy to cool my a64 2800 chip, i dont wanna spend more than 35 bucks. should i buy a vga fan too, i heard it gets hot
    3. Is a heat spreader necessary for my 1 stick of memory
    4. Should i get a sata hard drive, i have a 7200 maxtor 250gig hd, i can sell it to a friend for 130, do i buy 1 or 2 SATA harddrives?
    thank you for reading.
    james
    Jul 2004
    is this the wrong forum or something?
    Xtreme 3DMark Addict
    Sep 2003
    your a64 should come with stock heatsink/fan. use that. I got 2.2GHz stable at 1.7v on mine and it only runs lukewarm too, I can hold my finger indefinately. also you got some great ram, I have the same ram at 248fsb and counting. to overclock, just increase your fsb. I hope you hit at least 240x9=2.16GHz with your ram in sync
    3000+ Venice 240x9=2.16GHz(ondie controller limit) 2x512mb patriot tccd ram
    9700pro at 325/310 runs all games buttery smooth!
    9700(8 pipe softmod, 128m) at 410/325 23821 at 325/310 21287 at 275/270 19159
    9500(4 pipes, 128m) at 420/330 18454 at 275/270 13319
    9500(8 pipe softmod, 64m) at 390/310 19201 at 275/270 16052
    9500(4 pipes, 64m) at 400/310 16215 at 275/270 12560
    3dmark scores with Ti4200 and Ti4800se
    Ti4200 at 340/730 19558 at 300/650 18032 at 275/550 16494 at 250/500 15295
    3dmark scores with older gpus
    Ti500 at 275/620 14588 Ti200 at 260/540 13557 MX440 at 380/680 11551
    Xtreme Gamer
    Jan 2004
    Europe
    welcome
    1. This question is too general ...u shud do some research b4 asking the question "how do i overclock"
    2. if ur refering to a cooler ...the thermalrights are good.
    3. what memory do u have? ...since i doubt u overclock heavily and pump a lot of volts into them, u dont need it.
    4. sell the 250gb and buy 2xSATA HDD's (of the same type) and put them in RAID 0 (ur msi k8n neo supports this).
    Intel i7 930 @ 4.2Ghz 24/7
    Asus Rampage 3 Extreme
    Asus Radeon HD 6990
    Corsair Dominator GT 6GB
    Corsair AX1200, 600T
    Intel X25-M 160GB
    Dell U3011 30" Monitor
