Results 1 to 4 of 4
Thread: Athlon 64 2800+ overclocking
    Jan 2004
    How far will this CPU overclock on water?
    What is max voltage with water for everyday use? For benching?
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    I wouldn't go above 1.8volts for the vcore. A64's tend to be more sensitive to voltage than their predecessors. Maybe a bit higher for the 5 minute bench.
    And you'll have to try it yourself to find out how far it will go.
    Formerly XIP, now just P.
    Jan 2004
    Well I guess, there's not many out there with A64 2800+ yet.
    I might try one, but then again the 3000+ isn't much more expensive.
    Jun 2003
    that 9 multiplier would suck. get the 3000+.
    Asus G60VX : Intel T9600@3.299GHZ : Nvidia GTX260M @ STOCK/ .9v
