Results 1 to 5 of 5
Thread: AIW X1900 Pal (European) BIOS Wanted!
    May 2005
    Greece
    I flashed my card with the US (from techpowerup) bios and now i cannot get any channel's... If anyone has the Pal edition card, please share it's bios...
    Thanx!!
    Muslim Overclocker
    May 2005
    Canada
    You should be able to change it from with in the driver or from your software. Its only your initial TV mode that was changed to NTSC.
    I had an older ATI TV Tuner card, and I was able to do this with it. I remember one thing though, it was not easy to find.
    Or, you could try Rabit:
    http://www.techpowerup.com/downloads/283
    My watercooling experience
    Water
    Scythe Gentle Typhoons 120mm 1850RPM
    Thermochill PA120.3 Radiator
    Enzotech Sapphire Rev.A CPU Block
    Laing DDC 3.2
    XSPC Dual Pump Reservoir
    Primochill Pro LRT Red 1/2"
    Bitspower fittings + water temp sensor
    Rig
    E8400 | 4GB HyperX PC8500 | Corsair HX620W | ATI HD4870 512MB
    I see what I see, and you see what you see. I can't make you see what I see, but I can tell you what I see is not what you see. Truth is, we see what we want to see, and what we want to see is what those around us see. And what we don't see is... well, conspiracies.
    May 2005
    Greece
    Rabit doesnt work. There is no way to change anything about the TV-Tuner capabilities...
    Crunch-Fu Adept
    Sep 2005
    Czech Rep.
    Quote Originally Posted by ahmad
    if you could find any way to change the tuner settings, it would be great help ... Is it a switch in the driver?
    Sometimes a good slap in the face is all you need
    Bios my arss.....
    I can fix this problem with a hardware mod....
    Hipro5
    "Overclock till death. Overclocking is life." Hipro5
    Muslim Overclocker
    May 2005
    Canada
    It could be something only available in standalone AIW cards, but I have changed it before with my own hands. Default setting on my card was PAL, but I changed it to NTSC_M. I am sorry I don't have any AIW cards at the moment, so I can't tell you exactly where you can find it.
    Water
    Laing DDC 3.2
    Rig
