Results 1 to 17 of 17
Thread: ASUS A8N-SLI Dlx BIOS1014 HTT 280++
    THE ORIGINAL OC JEDI
    Oct 2002
    Field of Battle
    Looks like the new BIOS is the cure to our ills with the A8N-SLI Dlx...
    It's still not a SLI-DR but it's a step
    ANd it's 282 MEMORY SPEED, not just 282 HTT, previously there was a known bug limiting OC to 240, 1:1...
    C
    And yes, it's SP2004 stable for more than 33 seconds I just wanted to spread the news!
    Admin
    Feb 2005
    Ann Arbor, MI
    Good to know! Too bad there still isn't anything that can quite compete with the DFI (not that I mind--I love my DFI)
    Does it look like you can get more out of it than 280?
    May 2005
    Porto, Portugal
    With the 1013 it was capable of doing more than the 240 fsb.
    I tested it but not on 1:1
    Cumps
    Xtreme Mentor
    Oct 2002
    boston,ma
    Has anyone tested the an32 board
    Abit KN9-SLI
    X2 3800+
    1gb corsair pc5400
    2 evga 7900gt
    200gb maxtor sata
    ocz 520w
    heatware:althes
    ebay althes
    Xtreme Mentor
    Jul 2004
    Brooklyn, NY
    did they increase the vcore for x2 cpus?
    Asus Rampage Formula X48
    Intel Q9650 @ 4.33GHZ
    OCZ Platinum DDR2-800
    Palit 4870x2
    Creative Xi-Fi Extreme Music
    Corsair HX1000
    LL 343B Case
    Thermochill 120.3
    2xMCP355
    KL 350AT
    KL 4870X2 FC WB
    DD Chipset Block
    Oct 2002
    Field of Battle
    Quote Originally Posted by situman
    No, actually lower
    It maxes at 1.5v, but overvolts @ 1.52v
    C
    Xtreme Mentor
    Jul 2004
    Brooklyn, NY
    baaaaaah! hoping the a8n32 is better in that respect
    Palit 4870x2
    Corsair HX1000
    LL 343B Case
    Thermochill 120.3
    2xMCP355
    KL 350AT
    KL 4870X2 FC WB
    DD Chipset Block
    Jan 2005
    TN
    yay, i doubted they would ever get this fixed, especially after putting out the even more deluxe heatpipe etc boards.
    Dec 2004
    Is there no way of increasing the voltage? I building a system for a friend and I darn't use a DFI for him with the unreliability etc, I use one myself but the poor guy wouldn't have a chance if it needed the CMOS resetting the DFI way and I live 15 miles away.
    I want a good quality board that I can pre overclock for him so it's reliable.
    Would this fit the bill??
    Thanks..
    Silverstone TJ07
    i7 920
    EVGA X58
    Corsair Dominator 6gb 1600GT 2000MHz 8-8-8-20
    Thermochill PA120.3
    Big NG fan controller
    Heat Killer v3 CPU Acetal
    EK Full block GPU
    ATI 5870
    Corsair HX850
    1X 1TB Samsung
    1X 500GB Seagate
    1X Crucial SSD 64GB OS
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    use a fixed resistor for a .15 offset to the voltage, so 1.5 volts, is really 1.65 volts...
    so if you want 1.4 volts again, you just set it to 1.25 volts in bios.
    thats what I would do, with this board...
    (in case someones gonna ask, no I don't know the volt mods for this board, just saying, this is what I would do, to deal with the low voltages for X2's)
    Xtreme Cruncher
    Mar 2005
    venezuela caracas
    charlie sorry to bother you is this 1t or 2t?
    Incoming new computer after 5 long years
    YOU want to FIGHT CANCER OR AIDS join us at WCG and help to have a better FUTURE
    Nov 2002
    Juneau Alaska
    look closer at the picture...
    2t.... disabled.
    Xtreme Cruncher
    Mar 2005
    venezuela caracas
    my bad thanks for pointing that out kunaak
    Feb 2003
    Sweden
    @Charlie
    Have you checked that the htt is not locked to 3x?
    I know that with that Ai Overclock program one could see that multiplier from winXP.
    Ever since 1002 bios my a8n dlx mb has had a looked htt multiplier. But at some never version (may have been 1012 or 1013) they changed from locked 5x to 4x. That changed my max to about 240mhz htt from 22xmhz. Could you check if that it isnt just locked to 3x or lower? I have only succeded with changing it when using bios 1001 but then i can reach about 310mhz htt (with mem divider ofcourse).
    Sorry if my english is not as good as it could be.
    X3520
    R2E
    Corsair DDR3 1600mhz
    X25-e
    2xCorsair S128
    GTX 295
    Feb 2003
    Sweden
    Charlie have you checked if the htt is still locked?
    X3520
    R2E
    X25-e
    2xCorsair S128
    GTX 295
    IT Engineer in the making
    Jun 2003
    Former Kingdom of Bavaria
    Great to hear that as I bought an A8N SLI deluxe this week without knowing about it's bugs (got it very cheap, that's why). Then I read about the problems and got a bit scared.
    But now that you prove what I was already hoping, it's all OK. Really happy to see that Asus finally got the big probs fixed with a new bios.
    Oct 2002
    Field of Battle
    It's an OK board... for less than HUGE OC's... it's fine
    C
