Results 1 to 11 of 11
Thread: Asus A8N better vcore guide
    Sep 2003
    Denmark
    May be a lot knowing this but hope it can help others.
    Download ClockGen for NF4 and make a shortcut to the ClockGen.
    Make a .txt file with info like
    [CG-NVNF4]
    VID=1.550
    FID=13
    FSB=230
    PCI-E=100
    In the shortcut you add "-file=xxxxx.txt" (more detailes look at homepage for ClockGen)
    ClockGen is at default set at VID=1.475, so this gives some extra vcore for the Asus A8N - instead of around 1.584 you will get around 1.664 vcore.
    You can for instance put the shortcut in the "startup" or place it on the desktop.
    I'll be looking into the vcore mod, but have not figured it out yet, so hopes this can be a small start
    Brian Hermansen...benching with Jacob Hansen
    3DMark01 42400 | Aquamark3 104762 | PiFast 34.58
    Running chilly1 cascade
    Xtreme Mentor
    Jan 2004
    Berkeley/Stanford, CA, USA
    can u set VID to 1.6 and get 1.71 etc.
    can you see the light? is it shining too bright? can you see the light at the end of the tunnel, i know i do, i know its true.
    Sep 2003
    Denmark
    No afraid not! But this make me hope that there is no vcore ovp. Think this 0.1v is better than nothing hehe.
    Jun 2003
    Singapore
    Great info, THANKS
    Gaming/General Usage | Win7 64
    Gigabyte GA-X58A-UD7
    I7 930 (3003A965) @ 4.2 (200x21; CL7-8-8-24/1600; VCore=1.35V)
    OCZ3F1600LV6GK 6Gb
    PowerColor 5970 @ 900/1110
    X25M 80G G1 X2 Raid0, Xonar D2X, Antec 1000W.
    Swiftech Apogee XT
    EK Waterblocks EK-FB KIT
    XSPC 5970 Full
    Swiftech MCP655
    Feser X-Changer QUAD 480
    EK-Multioption RES X2 - 150 Advanced
    Scythe GentleTyphoon 120, TJ07
    Dec 2004
    Belgium
    It didn't work for me. I have a max Vcore op 1.584V (as I already had) with Bios 1003-004, but isn't this because winchesters undervolt ??
    Intel Core 2 Duo E6600 @ 3.6GHz
    ASUS P5W DH Deluxe
    Corsair Twinx PC6400C4 4-4-4-12
    Leadtek PX6600GT TDH 128MB GDDR3 Soon DX10 G80
    2xWD 250GB SATAII 16mb
    Acer AL2423W 24" LCD
    Thermalright XP-120
    SuperPi 1M 13.329Sec
    Mar 2004
    doesn't work,
    going to try the new beta bios 1003-005
    Aug 2002
    there is a mistake, NO "" and it works
    TARGET:
    X:\...PATH...\CG-NVNF4.exe -file=savefile.ini
    Banned
    Dec 2004
    winchesters will give max .1v less than the newcastles and fx cpus becasue there defualt vcore is .1v less
    Aug 2003
    orange county
    posted this already
    heatware
    ebay feedback
    FX-55
    DFI NF4 Ultra-D
    XFX 7800GTX
    Kingston 2x512mb BH-5
    Vapochill LS
    Dec 2004
    UK (Oxon)
    I get 1.62 anyway from bios - with my winnie! If I set vcore to max - 1.6500 - I don't, I get 1.5. If I drop the vcore in bios to 1.6250 in bios I get 1.62! Mind you I doesn't do my OC any good . If I set vcore to 1.6375, I get 1.54. I don't really understand this!
    AMD 3800 X2, DFI NF4 SLI-DR, 2 Leadtek 6800GT, OCZ 3200 Platinum LE, OCZ 600.
    Dec 2004
    Belgium
    Quote Originally Posted by tombman
    TARGET:
    if I do this without de " then when I click OK it gives an error and with " it doesn't
    ASUS P5W DH Deluxe
    Thermalright XP-120
