A7V8X uses ST L6017BD (28 pin) as the voltage regulator.
I searched the ST database and could not find this IC.
I thought that it is the same IC as HIP 6017 (http://www.intersil.com/data/an/an9/an9800/an9800.pdf).
If this is correct, we could program Vcore upto +3.5V by programming VID input pins of the IC.
Or will a traditional vcore mod work (a resistor connecting FB1 to GND)?
