Just got my P5E and it's working fine but I have two problems.
I'm on 0203 BIOS (latest) and I can't install AI SUITE software. Installer programm always tells me "not for this chipset or to update the BIOS"...- but there is no later BIOS for this board.
I picked the latest AI SUITE version for P5E straight from ASUS site......![]()
Second problem is temp reading in BIOS, I'm on water and BIOS tells me 15°C IDLE - at 21°C room temp.......IMPOSSIBLE!
Ran the same CPU with the same WC setup on P5K Deluxe before and temps in BIOS were ~28°C IDLE.
So should I try the older BIOS 0107 or is there any other trick to make things work......???
Any kind of help very appreaciated ! Thanks !
Just got my
Saaya yupp, I agree
BULL$HITT !!!
