i got a p5w dh deluxe with a e6600 c2d [watercooled]
my memory is OCZ platinum ddr2 800[400x2 fsb].
i have my c2d overclocked at 400 fsb.
with these options i need to enable spd timing or the pc will not turn on.
using cpu-z im getting timings at 5-6-6-18-24 [ cas-ras delay-ras precharge-tras-trc].
i would like to buy memory with timings but i dont know what will work well with my mobo. ive been doing some reaserch and found that G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 http://www.newegg.com/Product/Produc...82E16820231065
would load at the correct timings, but i also found some forums claiming that it would not.i need to know if this memory would load correctly?
if not tell me what can
what memory would work well with my setup???
), Juan J. Guerrero
Saaya yupp, I agree
