Results 1 to 20 of 20
Thread: Need some help OC Q6600 with a P5N32-SLI Plus
    Oct 2008
    Utrecht Netherlands
    Hi,
    I'm a n00b with overclocking so maybe someone can help me.
    I want to oc my Q6600 to 3.4Mhz, now its running stable @ 3Ghz
    The only thing i have changed are :
    Memory 4,4,4,12,2 @ 2.2 Volt
    And change the fsb to 1333 and set it unlinked
    System specs
    Asus P5N32-E SLI PLus bios 0803
    Q6600 @ 3.0GHz
    Coolermaster Hyper 212
    2x 1gb Corsair Dominator pc6400 ( 4,4,4,12,2 )
    XFX GTX260
    Thermaltake Toughpower 600 Watt
    I am Xtreme
    Sep 2006
    Only thing to do is to drop multi to 8 and to use 425FSB... keep the ram at 850Mhz ( even loosen timings eg 5-5-5-15 2T , Tref 45 )
    Quads put a lot of strain on the poor 680I chipset and we noticed that 425 FSB puts less strain on the NB then eg 400FSB
    NB voltage could be as high as 1.45, 1.2HT:1.45, CPU VTT 1.45, SB 1.55... keep that NB well cooled plz
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
    Oct 2008
    Utrecht Netherlands
    Tnx for the quick replay,
    Just tried your settings, but the pc crashed in the bootup...
    I am Xtreme
    Sep 2006
    Fill this in plz with what you got set ( dunno is all corresponds this is the Striker template )
    AI Tuning: Manual
    Nvidia GPU Ex: Disabled
    LinkBoost: Disabled
    FSB - Memory Clock Mode: Unlinked
    x FSB - Memory Raio: N/A
    FSB (QDR), Mhz: 1700 (means 425FSB)
    Actual FSB (QDR), Mhz: 1700
    MEM (DDR), Mhz: 850 (means 425mhz speeds)
    Actual MEM (DDR), Mhz: 850
    Vcore Voltage: 1.5
    Memory Voltage:2.0
    1.2v HT Voltage:1.45
    NB Core Voltage:1.45
    SB Core Voltage:1.55
    CPU VTT Voltage:1.45
    DDRII Controller Ref Voltage:AUTO
    DDRII Channel A Ref Voltage:AUTO
    DDRII Channel B Ref Voltage:AUTO
    tCL (CAS Latency): 5
    tRCD: 5
    tRP: 5
    tRAS: 15
    Command Per Clock (CMD): 2 clock (2T)
    Advance Memory Settings
    tRRD: AUTO
    tRC: AUTO
    tWR: AUTO
    tWTR: AUTO
    tREF: AUTO
    tRD: AUTO
    tRFC: 42
    Async Latency: AUTO
    CPU Spread Spectrum: Disabled
    MCP PCIE Spread Spectrum: Disabled
    SATA Spread Spectrum: Disabled
    LDT Spread Spectrum: Disabled
    CPU Internal Thermal Control: Disabled
    Limit CPUID MaxVal: Disabled
    Enhanced C1 (C1E): Disabled
    Execute Disable Bit: Disabled
    Virtualization Technology: Disabled
    Enhanced Intel Speedstep Tech: Disabled
    LDT Frequency: 5x
    PCIEX16_1 Frequency (Mhz): 100
    PCIEX16_2 Frequency (Mhz): 100
    PCIEX16_3 Frequency (Mhz): 100
    SPP<->MCP Ref Clock, Mhz: 200
    Oct 2008
    Utrecht Netherlands
    When I use your settings, my pc won't even boot :p
    Also tried FSB (QDR), Mhz: 1600 but crashes after a view sec...
    Xtreme Cruncher
    Sep 2008
    Kansas City, Missouri
    Yeah I just got mine stable on 3.2 and I am having trouble anything over that on my 680i.
    If I get it stable on 3.4 or I am aiming for 3.5 or 3.6 I will let you know my settings.
    ~ Little Slice of Heaven ~
    Lian Li PC-A05NB w/ Gentle Typhoons
    Core i7 860 @ 3gHz w/ Thor's Hammer
    eVGA P55 SLI
    8GB RAM
    Gigabyte 7970
    Corsair HX850
    OZC Vertex3 SSD 240GB
    Oct 2008
    Utrecht Netherlands
    Quote Originally Posted by HuffPCair View Post
    Yeah m2, got t stable @ 3.22
    Vcore 1.4375
    15.000 points @ 3DMark06
    Xtreme Cruncher
    Sep 2008
    You should be able to lower the vcore a little more into the 1.3v area so that will keep your temps a little lower unless you are going higher. I tried 3.6 and it lasted for about 45min and then freezes on me so I just gave up 3.2 is fine for me.
    Also I right now I have my Vcore on 1.400 but I plan to see how low I can get that. Ill let you know.
    eVGA P55 SLI
    8GB RAM
    Gigabyte 7970
    Corsair HX850
    Oct 2008
    Utrecht Netherlands
    Vcore now @ 1.38 volt
    Just used Intel Burn Test ( 5x ) and still stable!
    Q6600 @ 3.2GHz
    XFX GTX260
    Xtreme Cruncher
    Sep 2008
    Awesome.
    What kind of temps are you getting.
    EDIT also I am havign problems with IntelBurnTest. I run stable on Prime for 24 hours with no problems but I fail on INTELBURNTEST everytime
    any thoughts
    eVGA P55 SLI
    8GB RAM
    Gigabyte 7970
    Corsair HX850
    Oct 2008
    Utrecht Netherlands
    With Prime95 idle 43c loaded 60c
    With IntelBurn idle 43 loaded 73 ( with CoreTemp ) 63 in Realtemp
    Awesome.
    Q6600 @ 3.2GHz
    XFX GTX260
    Xtreme Cruncher
    Sep 2008
    Idle I am at 30C ish a little lower
    then in Prime on real temp and core temp my highest temp is (real temp - 44C) (Core temp -45C)
    But I am having a problem with IntelBurnTest not passing. Right away it fails so I dont know what is going on there.
    eVGA P55 SLI
    8GB RAM
    Gigabyte 7970
    Corsair HX850
    Oct 2008
    Utrecht Netherlands
    Do you use a liquid cooler?
    Realy nice temps!!
    With Prime95 no reboots, but IntelBurnTest crashes... hmm try to change youre Vcore to 1.45 Volt
    And try IntelBurnTest again, if its running good lower the Vcore.
    Q6600 @ 3.2GHz
    XFX GTX260
    Xtreme Cruncher
    Sep 2008
    No its all air just in the antec 900 and I moved the back fan to the side and it is now an intake fan. Has cooled it much better then hving it as an exhaust and then I have the Tuniq 120 and its doing a good job.
    And ok Ill try that it keeps saying i failed the Lanpack test, but I do not know what that means lol Im still a newbie to all this.
    eVGA P55 SLI
    8GB RAM
    Gigabyte 7970
    Corsair HX850
    Xtreme Cruncher
    Sep 2008
    Just found a new test called Memtest a lot of people are saying if you can go with this one and not have any errors you are good.
    Here is a link try it out
    http://hcidesign.com/memtest/download.html
    I am going to try it out and see what I get.
    eVGA P55 SLI
    8GB RAM
    Gigabyte 7970
    Corsair HX850
    Xtreme Cruncher
    Sep 2008
    I just ran it for 45 mins and no errors, but I am going to let it go all night tonight and see if it can go through the whole thing.
    EDIT--- I just ran that memtest all night for over 12 hours and I only got one error which is good cause I think what caused it was me letting it go to sleep. (forgot to turn that off hehehe)
    eVGA P55 SLI
    8GB RAM
    Gigabyte 7970
    Corsair HX850
    Oct 2008
    Utrecht Netherlands
    Great news! are you going oc it to 3.4?
    Q6600 @ 3.2GHz
    XFX GTX260
  18. #18
    Xtreme Cruncher
    Sep 2008
    I got it to 3.5 and its stable. Im so happy going to stress test over the night and see how it holds up but so far its held up playing TF2 and Far Cry2 and temps are staying in the 30s. Im happy I didnt think I could get it to stay on 3.5 but it is working so far so we will see how the stress test goes tonight.
    eVGA P55 SLI
    8GB RAM
    Gigabyte 7970
    Corsair HX850
  19. #19
    Oct 2008
    Utrecht Netherlands
    Wooot thats realy nice!! 3.5Ghz!!
    How high is your Vcore?
    Q6600 @ 3.2GHz
    XFX GTX260
  20. #20
    Xtreme Cruncher
    Sep 2008
    Well it is set at 1.5v right now I am trying to get 3.6 thats my new goal. If I can get that stable Ill be done. Right now I have it set on 3.6 and its working fine, but I havent tested yet. So we will see.
    I dont think my RAM likes it at 3.6 cause at 800mhz they seem to get angry at me lol. So I may have to get some new sticks I dont know yet we will see.
    eVGA P55 SLI
    8GB RAM
    Gigabyte 7970
    Corsair HX850
