Results 1 to 22 of 22
Thread: 8800 GTX Electrical Noise Under Load
    Jun 2006
    Bridge of the Biliskner
    Question 8800 GTX Electrical Noise Under Load
    Hi,
    Just installed my 8800 GTX and I noticed while running 3D Mark I can here a slight buzzing noise. Previously I had 2x GTO's running in SLI and they were silent. I have heard something similiar on one of my X1900XT. Definately coming from the card and not the Seasonic 600W. It on a water cooled rig which is totally silent hence why I can hear it.
    The Fan is silent BTW
    Anyone else experiencing similiar problems?
    ZR30W | 800D | 2600K | MIVE | 580 HydroGen | X25-160 | Aquaero
    Aug 2006
    The Netherlands, Friesland
    Quote Originally Posted by The Asgard
    Hi,
    Thats nVidia style. Most nVidia card have those problems.
    I also know guys with GTO SLI who have also the slight buzzing noise.
    I hate the buzzing noise, my 6800GE had it to.
    If you have a dead silent pc the buzzing noises are really irritating.
    >i5-3570K
    >Asrock Z77E-ITX Wifi
    >Asus GTX 670 Mini
    >Cooltek Coolcube Black
    >CM Silent Pro M700
    >Crucial M4 128Gb Msata
    >Cooler Master Seidon 120M
    Hell yes its a mini-ITX gaming rig!
    Jun 2006
    Driving me nuts especially when the pitch changes with the load. For example panning the camera around in NWN2.
    Not sure what to do. Send it back and try for another. ummmm .. Hassle !
    Nov 2005
    UK
    Send it back if you can.
    http://www.silentpcreview.com/forums...ic.php?t=16658
    Could be lots of things, VRM's, a poorly assembled choke coil can vibrate, or even a capacitor can squeal with frequency change. Sometimes if you can find it, potting with hotglue can help. Pretty much though, it won't go away.
    i7| EX58-EXTREME | SSD M225 | Radbox | 5870CF + 9600GT
    Jun 2006
    Quote Originally Posted by fornowagain
    Trying to find out if this is a general problem with the 8800 GTX card. If not its going back. Hassle .......
    Xtreme Mentor
    May 2005
    Westlake Village, West Hills
    Most Nvidia cards have that from my experience. I haven't got a clue what is making it, if I cared I would look for it. My guess would be a choke....
    PC Lab Qmicra V2 Case SFFi7 950 4.4GHz 200 x 22 1.36 volts
    Cooled by Swiftech GTZ - CPX-Pro - MCR420+MCR320+MCR220 | Completely Silent loads at 62c
    GTX 470 EVGA SuperClocked Plain stock
    12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
    ASUS Rampage Gene II |Four OCZ Vertex 2 in RAID-0(60Gig x 4) | WD 2000Gig Storage
    Theater ::: Panasonic G20 50" Plasma | Onkyo SC5508 Processor | Emotiva XPA-5 and XPA-2 | CSi A6 Center| 2 x Polk RTi A9 Front Towers| 2 x Klipsch RW-12d
    Lian-LI HTPC | Panasonic Blu Ray 655k| APC AV J10BLK Conditioner |
    Jun 2006
    To be honest I have only heard it on my X1900XT and xt-x but never on an Nvidia. My GTO's were totally silent in every respect.
    Really dont know what to do. Just need some confirmation on if this is just a one off or all the cards do the same?
    Wanna look under my kilt?
    Jun 2005
    Glasgow-ish U.K.
    my 7800GTX 512 does it when switching between 2D and 3D. Cant remember if my other 7800 cards had them
    you sigged that?
    why?
    ______
    Jun 2006
    Well I decided to put the card in my Badaxe which is now in my media server and it didn't make the strange noise I have been hearing. Anyway to cut a long story short its coming from my Seasonic 600W. Funny thing is the PSU was the first thing I thought I had checked. The 600W Seasonic in my MCE doesn't make the same noise. PSU's I can sort we have loads at work so no hassle in the end. Now I can enjoy the card.
    Thanks for the help peeps. Its much appreciated
    Xtreme Guru
    Apr 2005
    Finland
    I also have that noise coming from my 7900GTO in some games during menus or videos. Already sent one in for RMA but the new card also has the same prob. So they refuse to send me a new card but I can get back my money if I want but I think I'll stick with it anyways as it doesn't happen in all games and not during ingame. I have lots if things on the 12v rail tho and my PowerStream 520W may be near its limits but still the noise definitely comes from the gfx card in my case.
    Intel? Core i5-4670K @ 4.3 GHz | ASRock Extreme6 Z87 | G.Skill Sniper 2x8GB @ DDR4-1866 CL9 | Gigabyte GTX 970 OC Windforce 3x | Super Flower Titanium 1000W | ViewSonic VX2268wm 120Hz LCD | Phanteks PH-TC14PE | Logitech MX-518 | Win 7 x64 Professional | Samsung 850 EVO & 840 Pro SSDs
    If all people would share opinions in an objective manner, the world would be a friendlier place
    Jul 2006
    The Swamp
    Very sad to hear hopefully they get this fixed. I wouldnt want a brand new card to have an electrical buzz
    Xtreme Guru
    Apr 2005
    Finland
    Well depends how you look at it, seems for most people without knowing it, this is FPS related and when FPS gets too high such as running 3Dmark03 on a very powerful SLI setup the noise appears. To me it seems like the cards comes closer to the physical limit of how many FPS it can render without causing the card to squeek.
    Yes I recently discovered this myself with my 7900GTO, when hitting very high fps rate especially during menus, dunno how high yet but at least way over 1000+ fps this noise appears. Vsync -> on removes the noise or setting prerender limit to 0.
    Would be funny to hear how much a 8800GTX SLI setup squeeks in FEAR menu with vsync disabled (from nvidia cpanel). This probably varies a bit from card to card too how much FPS it can take before it appears.
    In the thread starters case it was the usual PSU having noise instead tho, weird if even that PSU wasn't able to power your system fine tho.
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    My mobo makes that noise too and I agree it gets irritating after awhile. But when gaming I can't hear it so it doesn't matter much I guess.
    Almost everyone over at anandtech thought I was nuts and said I was just hearing things.
    The Cardboard Master
    Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
    May 2006
    My darn P5W DH makes this stoopid noise. I hate it. I don't think I've noticed any noises coming out of the 8800GTX yet - just the fan...a lot.
    MAIN: 4770K 4.6 | Max VI Hero | 16GB 2400/C10 | H110 | 2 GTX670 FTW SLi | 2 840 Pro 256 R0 | SB Z | 750D | AX1200 | 305T | 8.1x64
    HTPC: 4670K 4.4 | Max VI Gene | 8GB 2133/C9 | NH-L9I | HD6450 | 840 Pro 128 | 2TB Red | GD05 | SSR-550RM | 70" | 8.1x64
    MEDIA: 4670K 4.4 | Gryphon | 8GB 1866/C9 | VX Black | HD4600 | 840 Pro 128 | 4 F4 HD204UI R5 | 550D | SSR-550RM | 245BW | 8.1x64
    Xtreme 3DTeam Member
    Oct 2006
    I've had that noise when my cpu voltage was over 1.9v...
    the chip survived it though
    E6600 week 28, Asus P5B vanilla, 4.64Ghz,P5B vanilla w/ Vmods, vapochill and other stuff, Super Pi 1M = 11.0000s
    QX6700 on EVGA 680i w/ twin 8800 GTX's SLI
    Second Place hwbot 3DMark06 Sli 20999 (12/2/06 till ...???)
    May 2005
    Montana, USA
    My 8800gtx has this as well. Its fairly pronounced in 3dm01, but silent under 3dm05... Since all 8800 PCBs are created equal, its just something I'm going to live with. Havent treid any games yet (still benching) but hopefully it wont be noticeable in game.
    i7-2600K @ 4806Mhz 102.3x47 1.368v LinX stable
    MSI P67 GD-80
    16Gb Corsair 8-8-8-24 1T 818.2Mhz
    MSI GTX560Ti 1005/2250 1.062v
    Crucial m4 256Gb SSD
    Corsair TX850 | 64bit WIN7 Pro
    Custom watercooling
    47" 1080p LCD | Onkyo 876/ Polk 5.1 surround
    Apr 2005
    Mold,Wales
    Its is most probably caused by a inductor I wouldn't worry about it unless the sound is driving you mad if so try and send it back.
    Does anyone know where i can get bananas like this the only ones I can get don't dance and go black after a few weeks
  18. #18
    Oct 2006
    just a thought, but my 8800 gtx had a really bad whine if I connected power to the plug closer to the monitor cable. It literally screamed. I changed to the other plug and it went away.
    Is that normal?
  19. #19
    Nov 2005
    PHX
    My case isn't silent w/ 5 120 SFLEX E 49CFM, 21DB, but there's no "high pitched" sound here. I had an AA8XE that drove me up a wall...even with the relatively louder 80mm's being used at that time. My previous DS3 also had this wonderfully irritating noise. It wasn't near as bad tho. I'd def try another one.
  20. #20
    Jun 2006
    I think the trouble with this type of sound is its omnidirectional and difficult to pinpoint. I suspect inductive loading between cards/mobo can cause components to squeal. With my previous Seasonic 600 watt it was fine with a pair of 7900 GTO's which would have been <= a 8800 GTX.
    Thats the problem with silent systems there's always something thats just a bit louder than something else. Like chasing a rainbow.
  21. #21
    Xtreme Mentor
    May 2005
    I talked with Maxxxracer and we came to agreement that it is a fet understress. You can't fix it. It is normal and varries between cards.
  22. #22
    Feb 2004
    Ireland
    I am getting this sound too, but not constantly. It comes in waves, building up slowly in intensity, then fading away again. It's not really loud, but it penetrates your head.
    I can't really tell if it's coming from the PSU or gfx card. When I put my head near the PSU to listen, the sound is drowned out by the whirring of the fans.
    My current psu is a 500w Enermax Liberty, with dual VGA 6-pin PCI-E connectors, so it should be powerful enough for a single GTX. I was going to get a new PSU anyway, probably ~800w, so I'll find out if it's the card making the noise when the new PSU is installed.
    P5W DH | E6600 | 2Gb Geil | 8800GTX | Audigy 2 | Enermax 500W | 2407 A04
