bios set to 1.475v, cpu temp hits maybe 52c max with a freezer64.
been playing games on it for hours and its all good!!
*edit* stepping:
oem 4000+ SD
KAB1E
2206 (i think! defo made in 06 tho)
*edit* stepping:
oem 4000+ SD
KAB1E
Glad for u mate
Board: DFI LanParty UT X58-T3eH8 (2009-02-17)
CPU: Intel Core i7-920 Batch:3835A799
RAM: Corsair TR3X6G1866C9DF 3x2GB Dominator 9-9-9-24 1866 1.65V Triple Channel
GPU: ATI Radeon HD 4870 X2
Sound: onboard
HDD: 3x30GB OCZ Vertex RAID0 , 2X300GB VelociRaptor RAID0
DVD: Samsung SATA DVD/RW
PSU: Thermaltake 1200W
OS: Vista x64 SP1
Goddamn thats a hell of a 4000+
Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
MSI H55-GD65 Motherboard
G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
Sapphire Radeon 5750 1GB
Samsung F4 320GB - WD Green 1TB
Xigmatek Utgard Case - Corsair VX550
sweet.
[SIZE=1][CENTER]||DFI-NF4 ULTRA-D||Sapphire X800PRO VIVO PCI-E@570/570||AMD64 3200+ Venice@(250 x 10)@1.45v CIPW||Corsair Value Select 1GB(2x512)@216 2.5/3/3/7-1T||Antec SP 2.0 500W Dual 12vRails||XP PRO SVP 2||SONY DVD-RW||Lian Li PC-IIB |WD SATA 80GIG 7200RPM||
Super Pi 32m or prime stable?Originally Posted by zipp0r
DFI CFX3200
Opty 180 at 2730
XP-90C W/92mm Tornado
2X1024 G.Skill HX
Silverstone 520
Powercolor X1900XTX
He said game stable so obviously... it's stable.![]()
Where did it come from (Newegg / ZipZoomFly / etc)?
And as was already asked...perhaps you could share the stepping and date.
In memory of Gracie, my sweet, sweet wife and mother of my children. Darling, we will miss you dearly. May you rest in peace (born to this world on March 30, 1976; went to her Heavenly Father on Good Friday, April 22, 2011).
http://animoto.com/play/E0wFhd6tN0nA...ent=challenger
Heat
jesusing christ.
and i can barely do 2.6 GHz at 1.45v**
**its XtremeSystems, i have a not so great clocking X2 4400+, im going to complain about it every chance i get. wheres K8L already. why am i broke.
Computer:
Case: Corsair 750D Airflow Edition
Mobo: Gigabyte Aorus X570 Ultra
RAM: Team TForce Xtreem ARGB 3600C14 2x16gb XMP
CPU: AMD Ryzen 5900x
Graphics: EVGA (rip) RTX 3080 FTW3
PSU: Seasonic Focus GX 850w
Cooling: Arctic Liquid Freezer II 360mm
NVMe: SKHynix P41 Platinum, Samsung 980 Pro 2tb
SSD: Micron 1100 2TB, Samsung 860 Evo 1tb
HDD: WD SE 2TB, WD Black 1tb 3 platter with over 10 years of power-on time
sorry i didnt really pay much attention to the writing on the cpu. but it is OEM, stepping KAB1E or something. and the date i think was 2206.
http://www.overclockers.co.uk/acatalog/Socket_939.html <-- if u buy the oem from there, it will almost definatly hit 3ghz
link to the thread where people are oc'ing them: http://forums.overclockers.co.uk/sho...6&page=1&pp=30
it blue screened after several hours of prime95, knocked it down to 3150 and its been priming for 4hrs so far with no problems.
they're great clockers ....all hit 3ghz+ on air with low volts.
a little more if you have the equipment![]()
mouawad, did you find yours bsod when testing stability(with p95)? it'd be explainable if it was getting hot, but mine is 52c max
well a bit of heat isn't a problem under strong single stage![]()
but i will say that these 4000+ chips are the hottest i've ever used, by the looks of your PWM temps (69c) that could be the problem here.....you got a fan you can put across this area??? it might help you squeeze some more out of it.
Very nice 4000. Lately the X2 3800's have also been clocking very well. It seems that amd is finally letting us use the full potential of their chips with killer pricing to boot.
E8400 @ 3.84Ghz 1.25v LOAD
ABIT IP35 PRO
4 GB G.SKILL F2-8000CL5D-4GBPQ
EVGA 8800 ULTRA 660/1110
PC POWER & COOLING 750 QUAD
THERMALRIGHT ULTRA 120 EXTREME
2 X SEAGATE BARRACUDA ES.2 ST3250310NS 250GB RAID 0
pop the hood RIGHT NOW![]()
my 146 used to get hotter, but then it did need 1.58v to hit 2.8ghz. this needs 1.46v to hit 3150 and is coolerOriginally Posted by mouawad
yea pwmic is hotits a cramped area too so im gonna have trouble getting a fan down there.
i just wondered if yours whilst on the limit gives BSODs. or what else does it do?
That's *partly* because it is the 110W version, the 89W CC1BE's are kickin ass,Originally Posted by breakfromyou
2.8 at stock - 1.4V....
Abit IP35 Pro
Q6600-L26A976(lapped)@3.6--450FSB
TT Big Typhoon(lapped)
Crucial Ballistix Tracer 8500C5:5-4-4-7-30@1080--5:6 2T
PNY 8800GTS 640mb@630:10000 3D06--13170![]()
Ultra X-Infinity 800W
DFI SLI-DR
A64 x2 4400+@305 x 9 * 5/6
G.Skill HZ PC4000:3-4-4-8
2GB 1:1 3-4-4-8/ 1T@2.7Vdimm
2x XFX 7600GT XXX SLI@610:850
Antec TPower2 550W
i normally get freezing when pushing too hard, my problem is coldbug....i've had it upto 3670 for a screenshot but it freezes pretty much straight away. the 12x multi helps a lot i can clock this alot higher than my 148 opteron which was decent but after a certain point coldbug just takes overOriginally Posted by zipp0r
i think 3.1-3.2 under air is the best i've seen for these late production 4000+ so you're probably just hitting the wall.
btw where abouts are you located?? do you have same KAB1E stepping?
uk. and yes.Originally Posted by mouawad
well im 10hrs stable in p95 at 3150i'll leave it at this and see how it goes for a week or so and then cool my pwmic and ram and then see if i can go higher (stably!!). im sure it could do a 3.3 - 3.4 suicide shot, but id like to keep my windows working :P
with that 3.5 GHz screenshot, what kind of cooling is that?!
my 4400+ is 110wi should get an 89w one just because i hate this 110w one.
Computer:
Holly.. Impressive. I never overclocked my 4000+, at least not really, I sold it before I got the chance.
PC Lab Qmicra V2 Case SFFi7 950 4.4GHz 200 x 22 1.36 volts
Cooled by Swiftech GTZ - CPX-Pro - MCR420+MCR320+MCR220 | Completely Silent loads at 62c
GTX 470 EVGA SuperClocked Plain stock
12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
ASUS Rampage Gene II |Four OCZ Vertex 2 in RAID-0(60Gig x 4) | WD 2000Gig Storage
Theater ::: Panasonic G20 50" Plasma | Onkyo SC5508 Processor | Emotiva XPA-5 and XPA-2 | CSi A6 Center| 2 x Polk RTi A9 Front Towers| 2 x Klipsch RW-12d
Lian-LI HTPC | Panasonic Blu Ray 655k| APC AV J10BLK Conditioner |
p95 pass 24hrs :
Rebinned FX-57's anyone?![]()
