sorry about the quality the digicam is crap and the room being at the back gets no light even the bedroom light isnt enough lol
XP2600 @ 2300mhz 210FSB/420DDR
ABIT NFS-7 1.0
RADEON 9700@9700pro
WIN2kSP4
It's an easy mod, but It's a good method to make your system cooler
AMD Athlon 1700+ JIUHB
Abit NF7-S Rev 2.0
2x 256MB PC333 Infineon @ CL2 2-2-5
GeForce4 Ti 4200 64MB @ 300/600
Good job. You gotta start somewhere, and anything that keeps your components cooler is a step in the right diretion. Now for your next mod you should put some ramsinks on that video card to really make good use of those fans. Then you should be able to get alot more performance out of your vid card.
It can be an easy mod, but he did it on a steel case which makes it a ton harder and he's got two fans there which means that everything has to be lined up pretty tight so it looks as nice as his.
The only sugestion I would make is for future blow hole mods is, use 120mm fans, they move just as much air and they are a lot quieter.
All in all, damn fine work though
P4@4.44 @ 1.90v
Dual Vapochill PE's
P4G8X
Corsair XMS3500 Cas2
Vantec 520w PSU
9700 pro @ 425/??? W/ MCW50-T
4440 MHz of Sandra proven performance
And I have videos to prove it.
Wow thanks for that
When i had my first side fan attached temps never got over about 44C even when gaming but now the other fan is in , temps dont get over 42C which is great
ABIT NFS-7 1.0
RADEON 9700@9700pro
WIN2kSP4
now you need a 120 on top blowing out
P4@4.44 @ 1.90v
Dual Vapochill PE's
P4G8X
Vantec 520w PSU
Nice job!
Suggestion to make taking off that side panel a lil easier for yea.
Side Panel Fan Mod
Saw this recently and its a hella idea!
hehe aaron in due time
And IFMU interesting read ill think about it, at the moment i like what ive done but ofcause knowing me i get bored and do more things
ABIT NFS-7 1.0
RADEON 9700@9700pro
WIN2kSP4
