Hi
I would like to place a switch in my abit nf7 in order to turn it on when I use it out of the case
is it possible?any ideas?
in the pic are the 2 pins ...
thanx
Hi
thanx
I've done it on both my NF7-s and my DFI infinity, but I've got reset added as well. You just need to solder a switch between 2 points. I'll check which points I used later
hello.that is very easy to do.you need a momentary switch.which is what the power switch and reset buttons are.
here is a pic of the 2 i made up.hope that helps
very good jtf
thanx a lot guys
There's also a very easy way to start the board outside the case without any switch. Just use a screwdriver to short the correct pins et viola, the board will start or reset (depending on which pins you shorted). All you will need is a screwdriver, the motherboard manual and a steady hand.![]()
lol,thats quite funny,i like my way better thanksOriginally Posted by celemine1Gig
Yeah, I use a screwdriver as well (or a paperclip) Its not as dodgy as it sounds, honest![]()
Probably not a good idea that...
screwdriver, scissors or needle nose pliers
Rig 1 Asus ROG Strix B550-F WiFi, R7 5800x, 64GB Vengeance LPX 4*16GB, Zotac GTX 1070Ti, X-Fi Titanium, Enermax Revolution D.F. 850w, SSDs 768GB, HDD 3TB, CM 912HAF, NH D-15 Black.cr
Rig 2 Asus Maximus VI Hero, i7 4770K@4000, 32GB Ballistix VLP 4*8GB, Gigabyte GTX 970, eVGA G3 850, SSD 512GB, HDD 2TB, TT Element-T, NH D-14.
yes, a screwdriver works fine for me to.
San diego @ 3.2Ghz 1.5v(mcw6002)
DFI NF4 SLI-DR Expert
ASUS 7600GT SLI
2x256mb bh6 @ 266mhz 2-2-2-5
antec 430w
