Recived my Diego (CABGE 0522TPMW) some days ago, and are now benching with air, but later on it will be LS all the way
System:
- DFI nF4 Ultra-D
- 3700+ San Diego
- 1Gb OCZ VX 3200
- ATI 7000 PCI 64Mb
- Seagate 120Gb ATA
- OCZ 520W Power Stream
Cooling:- Vapo LS
- SLK-948U + Delta 80mm
Some cleaning befor the actuall test..
In the dark the camera needed such a long time to focus so the picture arent that great..
__________________________________________________ _
Test [air]
Click for bigger (1600x1200)
Memmory is at 200MHz so the points are far from briliant, with this bios 6.23-2 I reched at most 2830MHz with a deacent high voltage.. Im now using the 5.10 XCEL2-LL bios
The problem now is that I'v started to clock the memmory with a 180 divider. 280x10 so the FSB is 254. But when I tried SuperPI with the clocked memmory I get exactly same score. Whats wrong here? Its like the memmory clocking aint working as its so possed to..
Whont go under 29s witch is weird, ,my winchester would do the same, with 290FSB 2.5-4-3-6. But now with 255FSB 1.5-2-2-2 the same points... seems weird to me.
Some of the voltage are probably to high on this screen, but the memmory would probably do the same with 3.5/3.6V.
