Results 1 to 5 of 5
Thread: ....Thermaltake Tower 112....
    Feb 2005
    Ok so, as some of you know i bought a Cooler Master Hyper 6 and it performed like .... well not good. Sooo i returned it and got a Thermaltake Tower 112. The Cooler Master was so much easier to install. But one BIG problem i have with the Thermaltake is that it was not made correctly, it was made so that the fans are towards the vga and psu. So yeah im ognan return it.
    ok here are the results (not overclocked):
    Cooler Master Hyper 6 with cm's fan-
    Idle-42*C
    Load-50*C
    TT112 with 2 deltas-
    idle-40*C
    load-49*C
    My case temp is 24*C. I think i am supposed to get like 35*C idle at least and like 45*C load at most. With stock intel cooler i get idle-42*C and load-53*C. So WTH?
    Can someone please please please help me.
    Intel E6300 1.86ghz @ 3.6ghz w/ Zalman CNPS 9500
    Gigabyte IP35 DS3
    Crucial Ballistix Tracer 4gb
    XFX 256mb 7600GS
    Seasonic S12
    1.5tb hdd space
    Dec 2004
    Romania
    What kind of TIM are you using ? And are you sure the heatsinks make good contact with the CPU ?
    Mar 2005
    Ontario, Canada
    The bottom af the 112 might not be flat.I have a silent tower and it was nice after a good lap job, only 5C higher than an xp-120 but with a custom fan mount for a 120mm fan it was only 2-3C higher.
    Rampage III Gene I7 950@4.48G--1.485V HR-02 12G G.Skill 1600-1.5V, GTX470-SLI@725core 1750mem, Antec P180 MINI
    Live Long And Overclock
    Sep 2004
    Quote Originally Posted by comrad
    Idle-42*C
    Load-50*C
    idle-40*C
    load-49*C
    Whoa...are those supposed to idle at 40C with a TT112 !!!??? Then what in the world were the temps with the stock cooler ??? 60C Load ?
    That's nuts...But i think i know the problem. You need some AS5.
    Perkam
    Feb 2005
    I am using AS5, the bottom of the tt112 is good.
    And right now im at 40..5*C idle and i ran Prime 95 for like 10 min and i only went to 45*C, pretty good, but my idle temp is way too high. And i re seated the h/d like 3 times already, same temps.
    Thanks guys!
    Gigabyte IP35 DS3
    XFX 256mb 7600GS
    Seasonic S12
    1.5tb hdd space
