Results 1 to 10 of 10
Thread: Stainless steel hose as tubing for a chiller?
    May 2004
    대한민국 강원도 원주시 Wonju, South Korea
    I was thinking about a design for a "portable" water chiller the other day and I came up with this problem: transporting a chiller while your (probably vinyl) tubing is frozen will likely break something. I know everyone says Tygon this and Tygon that, but what about using some stainless steel hose stuff sort of like this:
    http://images.people.overclockers.ru/26234.jpg (I "borrowed" the pic from Xooler in his DD Project thread in the Vapor Phase section.)
    Correct me if I'm wrong, but wouldn't that be very resistant to breakage when frozen? (I can't see stainless steel shattering at -30 C.)
    Thanks for any info!
    7700k @ 5.0GHz
    ASUS Z170-Deluxe
    2x8GB Avexir Raiden DDR4-3000 15-15-15-35
    Gigabyte Aorus 1080 Ti @ 2076/1500(6000)
    512GB Samsung PM961 + 840 Pro 256GB + some TBs
    Corsair AX1200i
    X-Star DP2710LED @ 110Hz + 40" Samsung TV
    CPU and GPU under water: 9x120 rad + 3x120 + 3x120
    ...and an HTC Vive!
    Nov 2003
    I think Tygon is rated at -40c but don't take my word for it. I'll do some diggin around later when I have more time.
    P4C800E DL,P4 2.4c @ 3.4(droop mod),1G Mushkin 3500 II 2,2,2,8 @ 3.1v,AIW 9800 Pro (450/370 @ 1.9v core),Audiology Platinum,2xDiamonds 8mb Raid0,Lian-Li Pc70,PC P & Cooling 510D,Plextor 708A,Plextor 52x32x52...water cooled...
    Jul 2004
    Leesport PA
    Thats correct -40c it is. It's currently what I use, and while it has not cracked at - 37, my lowest temp reached, I would never think of moving it while that cold
    Anyway, Stainless should hold up much better, is there a rubber lining inside that stuff? I forget whats in there. If I am thinking of the wrong tubing and its all metal even on the innerwalls, then it wont crack, but will get MUCH colder than plastic tubing does on the outside.
    Get ready for some good insulation if thats the case.
    But once again the metal tubing I was thinking of is braided stainless outsite with a rubber inner wall.
    Apr 2005
    Sarnia Ont Canada
    im using nylon braided 300 PSI max hose, its good for chemicals and it is super strong. 3/8 ID is totally flexible @ -30 and actually got the hose to kink with little effort, it was cold on the hands even holding it with a towel but the cold didnt seem to affect this tubing whatsoever.
    edit. if your close to me i could gladly hook u up with 5 or so feet of this hosing. free of charge.
    Nov 2003
    May 2004
    Quote Originally Posted by ][nSaNe
    Would you really do that? That is awesome, man! Can you send me a PM if it's possible? (I live in Madoc, Ontario, about 30 minutes south of Belleville.) Thanks a lot!
    7700k @ 5.0GHz
    ASUS Z170-Deluxe
    Corsair AX1200i
    ...and an HTC Vive!
    Jul 2003
    Rio de Janeiro - Brazil
    you can vuy clearflex 60 hoses. They support lower temperatures than tygon and dont kink like rigid hoses.
    Q9550 EO @ 4.1
    Asus P5Q Deluxe
    4 Gb DDR2 Gskill
    2xVelociraptors 300 gb Raid 0
    Sapphire Vapor 4870 1Gb
    PCP&C 750w silencer psu
    May 2004
    I keep reading about silicone tubing... it's supposed to be a lot more flexible at lower temps than PVC tubing like Tygon and Clearflex. Does anyone have any experience with it? Thanks!
    7700k @ 5.0GHz
    ASUS Z170-Deluxe
    Corsair AX1200i
    ...and an HTC Vive!
    Apr 2005
    Indy
    I was thinking about using soft copper. If your computer is hard mounted to your chiller then you will have no probs. I was actually looking at doing this before I lookid into water chilling just for the looks of it. All you would have to do is to have a short section of tygon from the copper to you blocks and pump. Once you bend the tube the way you want it will stay there.....Just a thought.. fire away...
    (Sam)
    "FEAR NOT" Isaiah 41:10
    MOBO - eVga 680i SLI 122-CK-NF68-A1
    CPU - E6400 @ 3.3 @ 1.25V
    Video - 2 x 8800 GTS SLI
    Cooling - Water cooled by Danger Den
    Display - 3 x 21" Sony Trinitron
    Case - Sunbeam Acrylic UFO case
    PSU - Tuniq 950 watt Miniplant
    May 2004
    Quote Originally Posted by samuknow
    An interesting idea, but I want to make my chiller as portable as possible, just in case I ever need to go to a LAN or something on short notice.
    About the silicone tubing, though... the average lowest "operating temperature" I see quoted everywhere is -80 C. So far I'm thinking about either getting some Clearflex 60 from here or some Primoflex silicone tubing for not much more. (That silicone tubing is said to be more flexible than Clearflex 60 and Tygon 3603 at room temp, and more resistant to cold.)
    7700k @ 5.0GHz
    ASUS Z170-Deluxe
    Corsair AX1200i
    ...and an HTC Vive!
