I need your help shaving off 0.4sek on my current best run. Im @ 30.468sek right now.
I cant reach higher clocks on the CPU with the 1.65vcore I'm feeding it right now, and I'm reluctant to give it more, since the CPU is only cooled by a CNPS7000B-Cu and I cant rely on the temp readings Im getting from the onboard temp-sensor. I do have the rig sitting horizontally in the window though. Its 2degrees C outside
Settings during current run:
Im running SuperPI @ high priority
Freshly installed XP Pro (I dont wanna spend the time getting and installing win2003 server)
Codereds optimal BH5 settings (as you see in pic)
I would really love to go below 30sek, but it might be impossible at the clockrate I've achieved. How do you see it?
