Results 1 to 10 of 10
Thread: pg27uq issue
    Sep 2006
    pg27uq issue
    i have a asus pg27uq monitor and sometimes it resets to 82 hz from 144 hz and i have to go back into the osd to enable 144 hz and then its fine
    it doesent happen often but is this something i should be concerned about?
    BTK is my initials if you were wondering.
    i7 8700K - RTX 3090 - 32 GB RAM - ASUS PG35VQ
    i5 8600K - GTX 1080ti - 16 GB RAM - ASUS PG27UQ
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    Ive had this issue on a different brand and I found that the cable quality was my issue. My issue happened after powering off and on as well as sleep to awake.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Sep 2006
    Quote Originally Posted by Charles Wirth View Post
    im using the dp cable that came with the monitor
    Sep 2006
    could you link me to a good quality one to buy
    Jun 2002
    Las Vegas
    Start by unplugging and cleaning the connector? No other cable you can swap out to try?
    Newegg.com
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Sep 2006
    Newegg.com
    i switched the pg279q and pg27uq dp cables guess ill see if that does anything?
    Jun 2002
    Las Vegas
    Its worth a try
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Sep 2006
    Its worth a try
    the one with the pg279q that i switched to the pg27uq was shorter maybe that could help?
    Jun 2002
    Las Vegas
    I am not sure, let us know.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Sep 2006
    it hasnt happened since but i decided to get this
    https://www.amazon.com/PG35VQ-Monito.../dp/B07VTTZ4TD
    and sell my pg279q
