Results 1 to 3 of 3
Thread: Quick Question
    Sep 2006
    Quick Question
    I am in the process of moving to a new house and I am also building a new PC (8700K/1080ti) system. I am going to wait until I move into my new house to build it as I already have all the parts.
    The only the thing is should I at least install that 1080ti in my current system or will I be CPU bottlenecked (as I probably already am)
    Currenntly running an 3770K at 3.9 Ghz with 16 GB RAM @ 1866 Mhz and a ASUS PG279Q 1440P 165 Hz Monitor with G-Sync
    I am running a GIGABYTE 1080 currently and usually play at 1440P ultra no AA with G sync 165 Hz
    Most games give me 70-100 fps except for a few really demanding ones
    my question becomes should I install my EVGA 1080ti in my current system with any noticeable gains? or will I be cpu bottlenecked or does it not make sense with G-sync or should I just wait until I move and open the 1080ti with the 8700K system
    BTK is my initials if you were wondering.
    i7 8700K - RTX 3090 - 32 GB RAM - ASUS PG35VQ
    i5 8600K - GTX 1080ti - 16 GB RAM - ASUS PG27UQ
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    You wont be bottle necked on minimum frame fate with the 3770k and a mild OC.
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    I agree, you will be fine. You are on SSD's and probably have good ram too.
    If you need some advice tuning the 3770K some just ask.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
