OCN2
Results 1 to 4 of 4
Thread: Iwaki RD-series power supply questions
    Xtreme X.I.P.
    Oct 2006
    I've got a pair of Iwakis just lying around, that I sort of want to use. Now, these things add alot of heat to the loop at full 24V, so running it at a lower voltage is probably wiser. I'm not making huge ass loops, at most 4 blocks and two Monsta's (240/360) or perhaps triple PA120.3's. I do have the trusty, old, Meanwell S-150-24, but then I'm stuck with the full 24V - unless I can somehow reduce the voltage. I know I've read that people run these at 18V, but not how The 2nd option is to grab an S-150-15, which should be adequate, I guess. Any thoughts?
    PS: where does one buy these pumps these days? Someone in a local forum was wondering where he could get one.
    --->TeamPURE<---
    Crunch-Fu Adept
    Sep 2005
    Czech Rep.
    I am curious for someone wise about this to reply and help you out due to Iwaki being sort of like a Chevy V8 of water-pumps, I guess, and I'm wondering how they are nowadays. Never owned one, but back in around 2007 was planning to implement it in a loop based on experiences shared here at XS.
    Check this out: https://endless-sphere.com/forums/vi...hp?f=2&t=42793
    Sometimes a good slap in the face is all you need
    Bios my arss.....
    I can fix this problem with a hardware mod....
    Hipro5
    "Overclock till death. Overclocking is life." Hipro5
    Jan 2004
    Around the corner
    I have an RD-30 with a S-150-24. The adjustment pot drops it down to 20.5v which was enough to save some power and heat for me.
    Main Comp (Win 7): ASUS R4E, i7-3930k @ 4.9GHz, G.Skill Ripjaw Z 4x4GB @ 2133MHz, ATI 6950flash/6970 Xfire, Custom Watercooling
    3x Asus VW246H eyefinity; Polk Audio Monitor 40's (L,R), CS10 (C), Klipsch KG^4 (S), Sony STR-DA1000ES; all in a custom built desk
    Server: (Ubuntu 11.04) i7-920 @ 3.8GHz, 24GB G.Skill
    Mar 2008
    Minnesota
    I ran RD-30 @ ~20v with a pot off Meanwell back in the day. I wouldn't go below 15v or you are just wasting potential and modern rads can handle the little extra heat from the pump no problem.
    http://martinsliquidlab.petrastech.c...mp-Review.html
    i5 2500K @ 4.9GHz+ 8GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 6 Asus P8P67 Pro CrossFire 6970's @ 950/1450
    Xeon X5677 @ 4.5Ghz 6GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 7 Gigabyte EX58-UD5 4870x2
    i7-880 @ 4.2Ghz+ (still playing) 4GB G-Skill RipJaws DDR3-2000 @2300Mhz CAS 9 Asus Maximus III Formula MSI Hawk 5770
