So my work laptop has a VGA out port and I have a Dell U2414H that has a DisplayPort, a mini DP in, a mini DP out, and two HDMI ports (that are already used and connected to two of my other systems).
I got a VGA to mini DP cable and when I plug it in, the laptop detects that there's a monitor present, but it can't/won't send the signal to it and I was wondering if there might be suggestions of things that I can try or if there's something that I can do differently to get it to work (preferably at the lowest cost possible).
http://www.microcenter.com/product/4...es_-_6ft_White
Help would be greatly appreciated.
Thank you.
