Pump Order ok?
I plan to adjust my setup to combine my 2 independent loops together.
The order will go from:
pump1->rad1->QD->cpu->QD->res1
pump2->rad2->QD->gpu->QD->res2
To:
A) pump1->rad1->QD->cpu->QD->gpu->QD->res2->pump2->rad2->QD->res1
or
B) pump1->rad1->QD->cpu->QD->res2->pump2->rad2->QD->gpu->QD->res1
Note that rad1 and rad2 are placed in the following config:
fan->rad1->fan->rad2->fan
Option B would be easier for me to implement b/c I simply swap the return qds that hit each res so that the cpu hits res2 instead of res1 and the gpu hits res1 instead of res 2.
However, I am not sure how this would impact temps verses option A.
- You may not post replies
- You may not edit your posts
Forum Rules
