DST Clock Changes
Good morning all,
I was just chatting with a friend and we were discussing what, if any, effects do DST changes have on BOINC.
1. If you are running Windows straight up then ... nothing to see here, move along ...
2. If you are running Linux then depending on the version of BOINC (I think it is 7.0.28 and higher) you may need to restart BOINC after changing your PC time to DST.
http://www.worldcommunitygrid.org/fo...ffset,0#415154
Thanks,
SC
- You may not post replies
- You may not edit your posts
Forum Rules
