what expander that support with this M1015 card? HP Sas Expander?
DNA = Design Not Accident
DNA = Darwin Not Accurate
heatware / ebay
HARDWARE I only own Xeons, Extreme Editions & Lian Li's
https://prism-break.org/
Here's winsat.
My Rig :
Core i5 4570S - ASUS Z87I-DELUXE - 16GB Mushkin Blackline DDR3-2400 - 256GB Plextor M5 Pro Xtreme
Nice performance.
Cant think of any alternatives at this price level.
Hardware:
Hello!
Couple of questions:
1. If I have understood it correctly, SAS9220-8i AKA IBM ServeRAID M1015 LSI 9220-8i PCI-E SAS RAID 46M0831 is rebadged LSI 9240-8i raid controller without raid5 support?
2. Is there any easy(read: cheap) way to get raid5 support for sas9220-8i card? Like it says in this link "Field upgradeability to RAID-5, -50 with ServeRAID M1000series Advance Feature Key" and "By connecting the optional ServeRAID M1000series Advanced Feature Key to the controller, users will be able to achieveRAID-5, -50 data protection and sup-port for self-encrypting drives". What does this feature key actually means?
3. My motherboard doesn't have sata 6Gb ports so I was thinking, will vertex 3 saturate sas9220-8i card?
heatware / ebay
Thank you for your quick reply.
But that raised couple of more questions.
1. So actually you can have a dirt cheap raid5 card just by placing a simple jumper, or it's a some special jumper? Because I don't understand why people here are spending another 130$ for something you can do it yourself?
2. Merely I was thinking on getting one of these cards for 2 vertex 3 raid0 setup, but if I could it get with raid5 also, it raised a question. Can the card handle 2 vertex 3 raid0 and 4 samsung F3 equivalent raid5 setup without saturating?
Its a special jumper, costs $120 or so
Ref the throughput:
2 * Vertex 3 = max 1100MB/s
4 * Samsung F3s = (4 * 150MB/s optimistic) = 600MB/s?
Its possible you may saturate the card but if you are going RAID 5 then really you should be looking at the 9260 or better still the 9265 which has a big improvement in RAID 5 according to docs released by LSI.
FX 8350 @ 4.92 | FX8320E @ 4.8 | Asus Sabretooth FX990 R3.0 | 16GB GSkill TridentX 1600Mhz @ 7-8-8-10 | AMD R9 290 | Samsung SM950 Pro 500GB | Toshiba X300 4TB | Be-Quiet! 650W P8 PSU | Dual DDCs | EX Supremacy | EK R9 GPU | RX360 | RX240
My Rig :
EDIT: New driver 4.33 (unsigned) and firmware (20.10.1-0029 (APP-2.120.24-1181)) are available http://www.lsi.com/channel/products/...-8i/index.html
Code:CHANGELOG Driver: ******************************************* LSI Corp. MegaRAID Windows Drivers ******************************************* Release Date: 03/04/11 ====================== Supported Controllers ================== MegaRAID SAS 9240-4i MegaRAID SAS 9240-8i MegaRAID SAS 9260-4i MegaRAID SAS 9260-8i MegaRAID SAS 9260DE-8i MegaRAID SAS 9261-8i MegaRAID SAS 9280-4i4e MegaRAID SAS 9280-8e MegaRAID SAS 9280DE-8e MegaRAID SAS 9280-24i4e MegaRAID SAS 9280-16i4e MegaRAID SAS 9260-16i MegaRAID SAS 8704ELP MegaRAID SAS 8704EM2 MegaRAID SAS 8708ELP MegaRAID SAS 8708EM2 MegaRAID SAS 8880EM2 MegaRAID SAS 8888ELP Component: ========== SAS MegaRAID Drivers for Windows Release Date: 03/04/11 Version Numbers: ================ Current Version 4.33 Previous Version 4.32 Contents: ========= This package contains drivers for the following Windows versions: Windows 2003 x86 Windows 2003 x64 Windows Vista x86 Windows Vista x64 Windows 2008 x86 Windows 2008 x64 Windows 2008R2 X64 Windows 7 x86 Windows 7 x64 Windows XP x86 Windows XP x64 Install the driver from the appropriate folder for your Windows version. Bug Fixes/Enhancements: ======================= LSIP200123019 (DFCT) iMR performance degraded with multiple VD/ Sys PD. LSIP200122845 (DFCT) OCR support for 1078 LSIP200122850 (DFCT) Fix order of order due to IO coalescing. LSIP200122846 (DFCT) set issgl64 for mfiIoctlDcdbpath Known Restrictions: =================== 1. NONE Known Bugs: =========== 1. NONE Installation Instructions: ========================== Please refer to the MegaRAID SAS Device Driver Installation Guide.Code:CHANGELOG firmware: ************************************ LSI Corp. MegaRAID Firmware Release ************************************ Release date: 03/04/11 ====================== Supported Controllers: ====================== MegaRAID SAS 9240-4i MegaRAID SAS 9240-8i Component: ========= SAS MegaRAID Firmware Release for MegaRAID Controllers Release date: 03/04/11 Version Numbers: =============== Current Firmware Package: 20.10.1-0029 Current Package Details: APP-2.120.24-1181_BB-2.02.00.00-0001_BIOS-4.21.00_4.11.05.00_0x05000000_WEBBIOS-4.0-44-e_32-Rel_PCLI-03.02-01500008_NVDATA-3.09.03-0011_2011_02_12 Previous Firmware Package: 20.10.1-0020 Previous Package Details: APP-2.120.14-1094_BB-2.02.00.00-0001_BIOS-4.20.00_4.11.05.00_0x0418A000_WEBBIOS-4.0-43-e_31-Rel_PCLI-03.02-01500008_NVDATA-3.09.03-0010_2010_12_06 Bug Fixes and Enhancements: =========================== Firmware: ========= LSIP200141662 (CO) (auto4comp FW_SAS_LSI) Deliver HII in Q1 2011 Liberator maintenance LSIP200142547 (DFCT) Provide mechanism to bypass settings delayPOST and envDelaySOD LSIP200143179 (DFCT) (CL LSIP200142502) Return status code 'Success' to certain obsolete SCSI commands LSIP200139759 (DFCT) (CL LSIP200121783) With multipath setting, potential data integrity issue while IOs across 2 enclosures LSIP200143213 (DFCT) (CL LSIP200136622) potential I/O miscompares when issue OCR. LSIP200121969 (DFCT) FW 10M09 cause system (sles11sp1/rhel6) reset while lspci -vvxxx is used LSIP200071988 (DFCT) Inconsistent drive state after drives are changed to different slots. LSIP200139722 (DFCT) (CL LSIP200095564) Controller hit montask during BGI LSIP200139711 (DFCT) (CL LSIP200096531) fw hit montask at pd.c when rebuilding from raid 6 LSIP200139713 (DFCT) (CL LSIP200085772) Clear configured with SSC degraded causing FW went to mon_tsk() LSIP200139762 (DFCT) (CL LSIP200125260) Configured PDs become not supported PDs, LDs dropping offline. LSIP200104775 (DFCT) Controller reports "phy is bad" for single port with any SATA device LSIP200139764 (DFCT) (CL LSIP200095287) HSP commissioned alarm beep goes away after reboot LSIP200139742 (DFCT) (CL LSIP200086083) sscd show 0 byte in debugger and MSM LSIP200139756 (DFCT) (CL LSIP200099072) ekms bios is not enable LSIP200139728 (DFCT) (CL LSIP200089519) FW aborts the recovery resulting SES not responding LSIP200139758 (DFCT) (CL LSIP200095566) Drive comes up as unconfigured bad while running power cycle and error injection script LSIP200123091 (DFCT) DateOfFirstuse is Incorrectly Causing BBU Deep Discharge Requirement WebBIOS: ======== LSIP200123117 (DFCT) Using the "+" character caused uEFI WebBIOS to replace the + with a space and fail. BIOS: ======== LSIP200134837 (DFCT) FW revision is not displayed in the Bios' controller list LSIP200141091 (DFCT) Remove JBOD message form BIOS POST Installation: ============= Use MegaCLI to flash the SAS controllers. MegaCLI can be downloaded from the support and download section of www.lsi.com. Command syntax: MegaCli -adpfwflash -f imr_fw.rom -a0
What sickening is that 2R0 X18-M Gen 1 on PCH produce this. Very low latency and excellent write speeds. I will soon have SATA 6G pair, will be interesting.
Sony KDL40 // ASRock P67 Extreme4 1.40 // Core i5 2500K //
G.Skill Ripjaws 1600 4x2Gb // HD6950 2GB // Intel Gigabit CT PCIe //
M-Audio Delta 2496 // Crucial-M4 128Gb // Hitachi 2TB // TRUE-120 //
Antec Quattro 850W // Antec 1200 // Win7 64 bit
I'm intrigued by these, unfortunately, between a low budget, and the only ones I can find that are cheap to ship is a pair of two at (surprisingly) something like 100 bucks+20 shipping (for a pair!) they'll have to get shelved for a while
Current System:
eVGA 680i SLi "A2" P30 BIOS
intel Core 2 Quad Q6600 (currently at stock)
OCZ ReaperX 4GB DDR2 1000 (running at DDR2 800 Speeds with cas4)
320GB Seagate 7200.10
XFX 8800GT XXX 512MB (stock clocks)
auzentech X-Fi Prelude
PC Power and Cooling Silencer 750 Quad Copper
Win XP Pro
updated my M1015 yesterday with the latest FW, MSM and drivers without any issues. It didn't affect the array (Virtual drive) I had on. Not sure yet if there is any improvements.
That was on my EVGA SR-2
Henrik
Henrik
A Dane Down Under
Current systems:
EVGA Classified SR-2
Lian Li PC-V2120 Black, Antec 1200 PSU,
2x X5650 (20x 190 APPROX 4.2GHZ), CPU Cooling: Noctua NH-D14
(48gb) 6x 8Gb Kingston ECC 1333 KVR1333D3D4R9S/8GI, Boot: 8R0 SAMSUNG 830 129GB ARECA 1882IX-4GB CACHE - Scratch disk: 2x6R0 INTEL 520 120GB's, 2x IBM M1015/LSI 9240-8i, Asus GTX-580
ASUS P5W64 WS PRO, QX-6700 (Extreme Quadcore) 2.66Ghz, 4x2GB HyberX, various hard drives and GT-7600
Tyan S2895 K8WE 2x 285 Opteron's 8x 2gb DDR400 1x nVidia GT-8800 2x 1 TB Samsung F1 (not very nice) Chenbro SR-107 case
Monitors: NEC 2690v2 & Dell 2405 & 2x ASUS VE246H
I see no improvement on the latest firmware and drivers either.
--Matt
My Rig :
just got mine in today - will let you know how it works - gonna try to implement a RAID 1 on Ubuntu now
update: realized mine wasnt including mini SAS to SATA cable - will update once i get the cable in
there are good long cables on eBay for $15 i bought 4 and they have been fine.
Henrik
A Dane Down Under
Current systems:
dang, just spent 30 on amazon - but one day shipping
MAIN PC: CPU: Intel Core 7 920 D0 , MB Evga SLI MCRO X58, RAM: Corsair Dominator DDR3 1600MHz 6GB, GFX: 6970 2GB , OS HDD: Intel 40GB , Intel 160GB G2 SSD, WD SCORPIO BLUE 500GB, Case LIAN LI PC-V354 , Windows 7 Ultimate
FILE/MEDIA Server: MB: Supermicro X8SIA-F , CPU: Intel Xeon Quad-Core - X3460, Raid card: Areca 1880i+ HP SAS Expander ,CASE: Chenbro RM 414B , OS DISK WD Scorpio Black 160gb ,RAM: 4GB DDR3 1333MHz ECC/Reg ,PSU: Corsair HX750W , HHD: 10x HITACHI Deskstar 2TB, OS: Windows server 2008
Server2: MB: Tyan S5217G2NR-EFI Bigby-P, CPU: Intel Dual core , 4GB RAM , Areca 1680IX-16, HDD 10x WD Black 1TB
Any1 got any links to cheap RAID-5 keys for the M1015?
please
Henrik
A Dane Down Under
Current systems:
just double checking.. so ur M1015 is working with this:
http://hardforum.com/showthread.php?t=1484614
if so, which firmware & driver etc.. which mobo?
thank u muchly!
heatware / ebay
lulz...
that [H] page I linked you.. the first post has been screwed.. here is the post I wanted you to look @:
http://forums.servethehome.com/showt...xpander-Thread
(post#1)
this is the first time I have seen this post - I noticed it has been updated: this card is compatible
so now I'm really confused. in the [H] thread, ppl have tested with LSI 9240/9260 & it *hasnt* worked.. but this M1015 it does, yet its a rebranded LSI 9240..
I have a (probably dumb) question for everyone:
is this card a REAL HARDWARE RAID5 card?
or just a driver/firmware RAID5 card?
heatware / ebay
F@32,
Are you using the M1015 on your P67 Extreme4? I'm curious because I found out the hard way that the board doesn't like my Asus P8P67 Pro at all and I need a replacement board to play with .
Thanks!
All P8P67s dont have any PCI-E 8x slots, thus this card will not work with them. It requires an 8x slot.
Rig 1:
ASUS P8Z77-V
Intel i5 3570K @ 4.75GHz
16GB of Team Xtreme DDR-2666 RAM (11-13-13-35-2T)
Nvidia GTX 670 4GB SLI
Rig 2:
Asus Sabertooth 990FX
AMD FX-8350 @ 5.6GHz
16GB of Mushkin DDR-1866 RAM (8-9-8-26-1T)
AMD 6950 with 6970 bios flash
Yamakasi Catleap 2B overclocked to 120Hz refresh rate
Audio-GD FUN DAC unit w/ AD797BRZ opamps
Sennheiser PC350 headset w/ hero mod
heatware / ebay
