Results 1 to 18 of 18
Thread: Nikon D100 - $150, worth it?
    Xtreme Cruncher
    Dec 2008
    Los Angeles/Hong Kong
    Some of you guys might have known me in the Picture of the Day thread..
    Currently I am shooting with a P&S Sony DSC-H10; the more I use it, the more limiting I find it to be.
    First off, the lens is extremely narrow, 38mm at its widest setting. I am very interested in shooting cityscapes, and 38mm is not enough for me.
    Secondly, the noise level is way too high. I usually take night shots, when I forget a tripod, I am done for the day. ISO400 is already too much for me to bear.
    Time for a DSLR...
    I've found a deal on the Nikon D100 for $150.
    Also got a deal on the 20D for $225.
    The lens I am looking forward to get is the Tokina 12-24mm f/4.
    I am a bit leaning toward the Nikon since the Tokina is cheaper as a Nikon mount, about $330 from what I've seen. On a Canon it is normally sold for at least $400.
    Are there any better alternatives? I am not that high on cash so I would need a very inexpensive solution.
    Team XS: xs4s.org
    Xtreme Guru
    Mar 2004
    steelcity.pa.usa
    Quote Originally Posted by lkiller123 View Post
    Time for a DSLR...
    I'm not 100% sure, but pretty sure... that the D100 has the same sensor as the D70. IF that's the case then $150 for the D100 would be a great price. They seem to be selling for around $250 though... where the D50 and D70 can't really be found for less than $300. If that's you're tight on cash though it'd probably be your best option. Also dig around on FM forums. Often good buys to be found there.
    STARSCREAM
    3570k @ 4.6 GHz | Asus P8Z77-V LK | G.Skill F3-12800CL8D-8GBXM | ASUS GeForce GTX550 Ti
    Corsair Neutron GTX 240GB | Corsair Force GT 120GB | SK hynix 128GB | Samsung 830 64GB
    WD Black 640GB (3) | Seagate 7200rpm 1TB | Dell Perc H310 xflashed to LSI 9211-8i
    Corsair AX750 | CoolerMaster Hyper 212 | Antec P280 | Dell Ultrasharp U2410 | BenQ XL2420T
    ROCCAT Savu | Filco Majestouch-2 TKL w/Cherry MX Reds
    MEGATRON
    3770k @ 4.5GHz | Asus Sabertooth Z77 | G.Skill F3-12800CL8D-8GBXM
    SK hynix 128GB | Mushkin Enhanced Chronos 60GB | WD Red 3TB (4) | Seagate 7200rpm 3TB (2)
    WD Green 2TB (3) | Seagate 7200rpm 1TB | Dell Perc H310 xflashed to LSI 9211-8i (2)
    Corsair AX650 | Corsair H80i
    Xtreme Cruncher
    Dec 2008
    The $150 deal is from some posting on Craigslist. I've also seen some other D100s for around the $200 tag.
    A D100 around $200 and a 20D around $250, which one should I pick?
    Wow, just found a 20D for $225 with ~3600 shutter counts. Thanks for the FM link!
    Team XS: xs4s.org
    Xtreme Guru
    Mar 2004
    steelcity.pa.usa
    I'm not really familiar with the older generation Canon's so I don't really have anything useful to add for the 20D
    STARSCREAM
    MEGATRON
    Xtreme n00berclocker
    Mar 2006
    San Jose, CA
    D100 is from 2002. In the age of digital that should not eve be a consideration. If you tight on cash look at maybe something like the G10 or G11. No interchangeable lens but still has all the other options.
    Quote Originally Posted by 3oh6
    damn you guys...am i in a three way and didn't know it again
    Quote Originally Posted by Brian y.
    Im exclusively benching ECS from this point forward
    Xtreme Cruncher
    Dec 2008
    This will probably be my hobby for many years to come, so I am trying to have a nice SLR to get started.
    Team XS: xs4s.org
    Mar 2006
    San Jose, CA
    If this is going to be your hobby. Save up the money and buy a newer gen camera. D90s can be had for fairly cheap now around 700. Then invest in glass. You dont want to buy the D100 only to want a new camera in a month or two and have wasted money and time on the D100.
    Xtreme Cruncher
    Dec 2008
    Ugh, 700 dollars will take me years to save in my current condition. I am just a high school student, so I will be very, very tight on money. I am just trying to spend no more than $550 on a complete set.
    Team XS: xs4s.org
    Oct 2004
    London UK
    A Nikon that old may be in need of a service in a short while too. That is a very good price for the TOKINA 12-24mm f/4 IT IS >£300 in the UK
    Respec'
    System:Bunch of crappy overclocked PC's that cost an arm and a leg
    Mar 2006
    San Jose, CA
    You can get a Nikon 3100 with a 18-55 for ~$600. Look for maybe a D3000 used or used D3100.
    Xtreme Guru
    Mar 2004
    steelcity.pa.usa
    Quote Originally Posted by Planet View Post
    You don't know what you're talking about. A top of the line APS-C CCD sensor from 2002 can still be relevant today. There was only 1 generation difference between the D100 and the D3000. So the sensor in the D100 might as well only be two years old. There were some improvements in the D70 and the D50 so functionally they will be a bit easier to use. I would recommend maybe stretching your budget if you can and trying to find a used D50/70.
    For someone with a limited budget recommending and extremely overpriced kit with a lens that doesn't even suit their intended uses isn't the best advice either. The 3100 won't AF with the less expensive 3rd party lenses or older Nikon lenses whereas the D100/50/70 will.
    STARSCREAM
    MEGATRON
    May 2009
    Upstate, SC
    FWIW, i've done WORK with my D70... but a D100 is old crap you dont want to mess with... just like a D1...
    all D70 images of mine... either 50mm f/1.8, Tokina 12-24 f/4 or Tokina 80-400 f/4-5.6
    D70 w/ 70-200 f/2.8VR
    w/ SB-600 on camera...
    SYSTEM
    i5-3750K @ 4.6ghz - ASRock Z77 Extreme4 - 16GB Samsung DDR3 - Sapphire R7 370 Nitro 4GB
    Water Cooling
    EK Supremecy - DDC-3.2 w/XSPC Top -Swiftech MCR320-QP - EK Multioption 150
    Xtreme Cruncher
    Dec 2008
    Damn it, the listing is gone, now the cheapest D100 I can find worths 200 bucks.
    Just found another deal on the 20d WITH the 24-85mm. 200 bucks!
    Team XS: xs4s.org
    Xtreme Guru
    Mar 2004
    steelcity.pa.usa
    Quote Originally Posted by RoadconeTuning View Post
    I'd like to see some proof that the D100 is "old crap" compared to your D70. Considering they have the same internals... good luck.
    STARSCREAM
    MEGATRON
    Sep 2006
    as far as sensors go...
    D100 = D70 = D40
    just like
    D300 = D90 = D5000
    pretty funny you are so positive about a D70 when a D100 has the same sensor.
    I'd say any DSLR would be good, but I'd stay away from the D3000. (I own one as a second body and can't stand it) it has horrible luminance noise despite having the same sensor as the D80, it is much worse in image quality. It takes Lightroom's new NR to get it clean, even at ISO 400.
    Keep looking for a used D100 or D70, either of those would give you great image quality.
    Xtreme Cruncher
    Dec 2008
    Well, if the D100 has the same sensor as the D70 AND the D40, I will give this another look. I am looking around and can sometimes find a deal at around or less than 200 dollars. D70s are slightly more expensive.
    Thanks guys for the help!
    Team XS: xs4s.org
    Nov 2008
    Heart of Europe
    If you want good old and somewhat cheap camera, get Konica Minolta Maxxum 7D (or 5D). Lens for that are cheap and pretty high quality.
    i7 930 D0 - 4,2 GHz + Megashadow
    3x4GB Crucial 1600MHz CL8
    Foxconn Bloodrage rev. 1.1 - P09
    MSI HAWK N760
    Crucial M500 240GB SSD
    SeaGate ES.2 1TB + 1TB External SeaGate
    Corsair HX 850W (its GOLD man!)
    ASUS STX + Sennheiser HD 555 (tape mod)
    Old-new camera so some new pics will be there.. My Flickr My 500px.com My Tumblr
  18. #18
    Nov 2008
    My advice to you will be to not overthink the decision so much, the difference between all these models is truly insignificant. The one think that i will make sure if i were in your shoes, is manual control so you can learn and practices skill that will carry over to the next higher model in the future.
    As far as the glass is concern, that's another story all by itself.
