Page 2 of 2 FirstFirst 12
Results 26 to 34 of 34
Thread: Best 4GB kit for 2500Mhz or higher 24/7 stable?
  1. #26
    Xtreme Guru
    Jun 2010
    In the Land down -under-
    Quote Originally Posted by hiwa View Post
    well, BBSE were very nice moduls for Overclockers and daily use users, better than Hyper caz they aren't fragile like hypers, but with higher tRCD we couldn't able to do +2400 or so with triplechannel (i tested them only in triple), really no one thought need test them with higher tRCD (no need do this if your kit can do tighter timing for higher performance ), it's like someone buy hyper MGH and run it 9-11-9 for daily use, make no sense
    no dubt buy BBSE if you can find them for good price and you want enjoy Performance overclocking, but for daily use trust me if you play MafiaII or latest games nothing change on your final FPS go for PSC
    Thanks for your input friend, might go with some g Skill psc's
    Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
  2. #27
    Quote Originally Posted by Kain XS View Post
    Nevermind... I solved the "problem" by downloading latest M3F 2001 BIOS. It seems 1801 BIOS hated my new kit.
    I'm using 1.35v for IMC and the're running OK at the moment. It's time to stress them.
    Nice to hear you resolved it
    Quote Originally Posted by Johnny87au View Post
    and LOL my friend got the kit (2000 6-9-6 X2) and they are better than mine, on E760 and 930 (nice IMC) with 1.45 VTT and 1900 6-8-6 1.67 playing games
    Quote Originally Posted by LardArse View Post
    i think you are asking the wrong person about safety limits, but
  3. #28
    Jun 2006
    México
    Do you know which ICs are under the heatsink of those Patriot Sector 5? If not, I'm taking those heatsinks off later.
  4. #29
    PSC @ 100% but we have a lot of PSC versions
  5. #30
    Jun 2006
    México
    Thanks, I'll upload a picture later. Do memory heatsinks really help cooling memory? Or is it better to take heatsinks off?
  6. #31
    for sure u need HS put the memories in freezer for 30 minuts then you can take off HS easy
  7. #32
    Jun 2006
    México
    One side of the heatsink fell off when I was installing a module in the RAM Slots... That should be enough
  8. #33
    Jul 2010
    Berlin, germany
    Lol- High-Quality Manufacturing
  9. #34
    Aug 2008
    his result is from one georgian OCer
    and everything under air
    can somebody xplain why his dual channel then performs that good ?
    only 2 cores in action
    thats right
    my g.skill perfectstrom 2000cl8 EOL
    100% hyper i had opened it
    one core in action only!!!
    http://valid.canardpc.com/show_oc.php?id=1069741
    ts just relaxed vali
    uncore went more roo
    My DDR2 Results:
    Cellshock GMH 8500 2GB-1508MHz 2.74v vldt
    Cellshock GMH 8500 2GB-1398MHz 4-4-4-12 2.74v vldt
    Cellshock GMH 8500 2GB-973MHz 3-2-2-1 2.74v vldt
    Cellshock GMH 8500 2GB-1000MHz 3-4-3-5 3.25v SP1M
    Mushkin XP 8500 GMH 2GB-1300MHz 2.45v vldt
    OCZ Reaper 1200MHz PSC-1406MHz 2.28v vldt
    Dominator 8500 GKX 2GB-840MHz 3-2-2-1 2.5v vldt
