the parts you need to buy depends on what you want.
for a chiller you need a compressor, filter drier and a condenser
than you need an expansion valve that could be a capillary tube or an thermostatic expansion valve. if you are using a thermostatic expansion valve you need a receiver and a sightglas and also a high pressure cut off switch.
the evaporator can be a large copper tube or a plate heat exchanger.
then you have two shrader valve one in the high pressure side and one in the low pressure side for your manifold to messure the pressure.
i prefere the solution with thermostatic expansion valve and plate hx:
more pics:
http://members.extremecooling.de/pat...YjgwODgzNTNkNw
