Does it matter which is the lead card in crossfire? Should the best overclocking card be the main display card if you have the 2 same card but one overclocks slightly higher?
Intel System
CPU: Intel i7 990x ES @ 4.2GHz 24/7 still kicking!
Mobo: Foxconn BloodRage X58 P11 Bios
Ram: Corsair Dominator 12GB DDR3
Water Cooling: Apogee XT, MCP655-B pump, MCR220 radiator, XSPC 5.25" Bay reservoir
Videocard: EVGA Nvidia FTW+ GTX 1060 6GB
OS HDD: Samsung 950 Pro 512 MB M.2
Strorage HDD: W.D. VelociRaptor 300GB
Storage HDD: W.D. 500GB
PSU: Enermax Evo Galaxy 1250 Watt
Case: Cooler Master Cosmos S
Roms: Lite On DVD Burner
Roms: Asus Bluray Burner
OS: Windows 7 Ultimate 64-bit
They both need to be at the same clocks so it doesn't matter as you are limited by the weaker of the two.
Feedanator 7.0
CASE:R5|PSU:850G2|CPU:i7 6850K|MB:x99 Ultra|RAM:8x4 2666|GPU:980TI|SSD:BPX256/Evo500|SOUND:2i4/HS8
LCD:XB271HU|OS:Win10|INPUT:G900/K70 |HS/F:H115i
@ chickenfeed : clocks do not need to be the same on ati cards . None is downclocking to the other either .
I want to know too what is the best setup actually and if higher clock speeds are better to have on the 'main' card .
Main rig 1: Corsair Carbide 400R 4x120mm Papst 4412GL - 1x120mm Noctua NF-12P -!- PC Power&Cooling Silencer MK III 750W Semi-Passive PSU -!- Gigabyte Z97X-UD5H -!- Intel i7 4790K -!- Swiftech H220 pull 2x Papst 4412 F/2GP -!- 4x4gb Crucial Ballistix Tactical 1866Mhz CAS9 1.5V (D9PFJ) -!- 1Tb Samsung 840 EVO SSD -!- AMD RX 480 to come -!- Windows 10 pro x64 -!- Samsung S27A850D 27" + Samsung 2443BW 24" -!- Sennheiser HD590 -!- Logitech G19 -!- Microsoft Sidewinder Mouse -!- Fragpedal -!- Eaton Ellipse MAX 1500 UPS .
Not sure whats better when you actually utilize both cards. But for the occasional app that lacks cfx support you'd want the fastest one as main
Asus Crosshair IV Extreme
AMD FX-8350
AMD ref. HD 6950 2Gb x 2
4x4Gb HyperX T1
Corsair AX1200
3 x Alphacool triple, 2 x Alphacool ATXP 6970/50, EK D5 dual top, EK Supreme HF
Fastest one as main.
Either way it will be like this:
Frame 1 time: 4.6 ms
Frame 2 time: 4.9 ms
Frame 3 time: 4.6 ms
Frame 4 time: 4.9 ms
...at least, thats the concept. reverse frames for lower clocked card as primary.
Non-crossfire games will utilize the primary card so I'd go with the faster one.
Smile
Thx guys
Intel System
