Results 1 to 7 of 7
Thread: Power up problem with 4870X2
    Mar 2008
    Minnesota
    I just got a Visiontek 4870x2 for a great price. When I install it into my rig and plug in the PCI-e power, the PC won't even flinch when I hit the power button. Not even the slightest sign of movement from fans or lighting or pump.
    Tried 2 different PSUs (Zalman 850w and OCZ 700w) with the same result. This leads me to believe a short in the card somewhere, any ideas where or how it could be shorting enough for the PSU's to not even power on?
    Just popped a GTX275 in there and it works just fine, posting from the machine right now.
    i5 2500K @ 4.9GHz+ 8GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 6 Asus P8P67 Pro CrossFire 6970's @ 950/1450
    Xeon X5677 @ 4.5Ghz 6GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 7 Gigabyte EX58-UD5 4870x2
    i7-880 @ 4.2Ghz+ (still playing) 4GB G-Skill RipJaws DDR3-2000 @2300Mhz CAS 9 Asus Maximus III Formula MSI Hawk 5770
    Jul 2008
    doesn't sound good bro, if you can get your money back that would be your best bet. Even if you find the problem could be a endless money pit. If you do to much to try and fix it, they're going to blame you for the symptoms.
    Asus Rampage Extreme x58, T.R.U.E. Copper
    I7920 SLBEJ 21 x 210, 6GB DDR3 Mushkin 1683
    Win7x64, 4870X2 Quad-fire + 240GT PhysX
    3dMark06 - 30,048 3dmark Vantage - 32,414
    [SIGPIC][/SIGPIC]
    May 2004
    Aland Islands, Finland
    Try and remount the heatsink + backplate, and check if you see anything weird at the same time... also try a different pci-e slot, but no power at all doesn't sound very healthy :/
    Asus Crosshair IV Extreme
    AMD FX-8350
    AMD ref. HD 6950 2Gb x 2
    4x4Gb HyperX T1
    Corsair AX1200
    3 x Alphacool triple, 2 x Alphacool ATXP 6970/50, EK D5 dual top, EK Supreme HF
    Mar 2008
    Minnesota
    Agreed, doesn't sound good at all.
    I'm going to take the card apart once and see if anything is blatantly wrong, just wanted to get a 2nd opinion and see if there was some known issue I could have missed.
    Hopefully Visiontek has a good warranty process.
    Mar 2008
    Minnesota
    For what it is worth...
    Took the card apart, found some staining under the heatsink as if it had been spilled on with some sort water cooling coolant (supposed to be a fresh RMA card.)
    Washed it with 93% alcohol, baked it for awhile at ~160F and put it back together.
    Works 100% fine now
    Jul 2008
    These cards are pretty tough, I've had a couple spills/leaks myself and been able to recover by just killing power ASAP and heat drying every component. Consider yourself lucky
    [SIGPIC][/SIGPIC]
    Dec 2008
    Buffalo NY
    I just had a cooling spill on my 1st wc attempt anyways that's a whole different thread...
    In any case the 4870x2 would power on but immediately hit max fan.. I shut it down as fast as a could move but it got soaked (barb cracked)
    took it apart, and there was coolant everywhere.. The heat pads for the memory were saturated and I removed them completely.
    hit it with the hairdryer for a good 30 min and popped her back in and she was perfect.. i cranked up the fan to 50 thinking it would keep it cool but it still idles right where it used to 63'
    i turn the fan to 50% and it sits at 42' ...
    i think i need some type of hs on the memory chips still.. i havent had any probs and benched with 3dmax 3x in a row np.
    but still the back plate isnt even touching.. so get pads somewhere or just order heat sinks or let it go ??
    Intel i7 2600K 5.0ghz
    Asus P8P67 EVO B3
    Swiftek Apex Ultra Cooling Kit
    Apogee XTL Block
    8 gigs Mushkin 2133 HS DDR3
    (2)PNY Nvidia 570 GTX DDR5 SLI Goodness
    Xonar DX1 Dolby Audio
    120GB RevoDrive SSD -WD Raptr150 + SG 750 x2 +Hitacchi 2TB
    Thermaltake Speedo Advanced Ed
    Corsair 1200AX PSU
