Results 1 to 9 of 9
Thread: 12th on RV770's Cross Fire
Hybrid View
    Nov 2008
    OCStreet Team Brasil
    Hey guys, I know it's not the best result, but since I'm having problems with temperatures, and seems that I don't have the greatest chip, that's how far i could get till now, on air:
    http://www.hwbot.org/result.do?resultId=862527
    My WC will be done in about 2~3 weeks, hope to improve that. It is a mild OC, and I hope to get on top ten still on air...
    Core i7 920 2.66 @ 4.2 Ghz Cooled By Thermalright True 120 Copper / eVGA x58 3xSLI / 3x2Gb RAM OCZ Gold 1600MHz 8-8-8-24/ TRI-Crossfire Sapphire HD4870X2 + PowerColor HD4870 1GB / 660 Gb Seagate(RAID0) / Zalman ZM1000-HP
    Diablo 3! Who's Excited?
    May 2005
    Boulder, Colorado
    Nearly 30k on air is nothing to be ashamed about
    Nov 2008
    Thanks gomeler..
    When I got the third RV770 I was hoping to get 30k.. then my 920 C0 was blocking it way too much. Plus, the powercolor card sucked. Couldn't over clock neither under clock it.. So i got a D0 and a sapphire.. But still 30k seems too much for the cpu I have here.. will try now to set more volts on gpus and oc that a lot
    With WC I might be able to get to 30k, since my D0 requires lots of voltage and things here are way hot :P
    Engineering The Xtreme
    Feb 2007
    MA, USA
    Air conditioning is the key
    Nov 2008
    Yeah.. I'll try with some conditioned air here.. And then I'll probably be the guy that spends most electricity in my city
    And things (and chicks) are hot here in Rio.. :P
    May 2005
    Boulder, Colorado
    Just watercool and put ice cubes on the radiator. This could get you the extra cooling you need to break 30k, you are really close.
    Xtremely unstable
    Aug 2004
    Between Hell and Nowhere
    That's a nice air run. I think with even a little bit cooler ambients and a little more volts you're at 30k easy. My D0s need volts like that too but I think it's due to temps. It's kind of a crude brute force ordeal.
    dx58so
    w3520@4100
    4x1gb corsair ddr3-1333
    gtx 295
    TR ultra-x, 2 scythe ultrakaze push/pull
    xclio stablepower 1000
    vista ultimate
    [SIGPIC][/SIGPIC]
    would you crunch if you thought it would save her life?
    maybe it will!
    Xtreme 3D Team
    Mar 2007
    Rio de Janeiro, Brazil
    Very nice run!
    AC unit and WC will help you to 30k
    You have to hurry up to take advantage of the somewhat mild temperatures we are having lately in Rio.
    [SIGPIC][/SIGPIC]
    Nov 2008
    Quote Originally Posted by [XC] gomeler View Post
    Dont know about the ice cubes yet, but I'm just waiting for performance-pcs to send my blocks..
    Quote Originally Posted by loonym View Post
    Thanks, unfortunately, that's the lowest ambient temperature we had for a looong time, don't know if it will wait for the WC
    Quote Originally Posted by NBF View Post
    Very nice run!
    Haha, that's true.. It had been a while since the last time I got these low temperatures..
    Hope the D0 scales way better on water, and will try to achieve 30k with a little more agressive OC on the video cards...
    Anyway, top ten is really close, all I need is a little over 29,2k...
