OCN2
Results 1 to 5 of 5
Thread: A Loop Question
    [XG] Xtreme Gamer
    May 2008
    Upper Peninsula
    A Loop Question
    Well, I'm getting a cosmos case, and it will not be able to be dremmeled or any modifications(not a normal cosmos). Could I cool lets say a E7200 and a GTX 260 55nm, with a feser or the like 240mm rad? Temps dont have to be uber, I just want it to be safe temps. E7200 will probably be oc'd too. Also, question #2 what parts would be best(gpu and cpu block, pump, etc) Would like it to be internal, and the top houses a 240mm rad.
    What I was thinking so far,,,
    Feser 240
    EK Supreme, DTEk Fuzion v2
    MCP355 w/ top
    Don't really know for gpu block
    Is that good?
    What about cooling a 9800GX2?
    I am Xtreme
    Oct 2008
    NY
    A Feser 240 will give you decent temperatures. Don't expect a great overclock, but it will probably be satisfactory. I would go with the GTZ or the Fuzion v2 because they are less restrictive in a multiblock loop.
    heat
    TJ07-Ultra 1200W-E8400-Rampage Formula-4870-4gb G.skill-74gb Raptor-500gb Seagate-Windows 7
    Apogee GTZ-XSPC Razor-DDC3.2 w/ XSPC top-PA120.3-MCR220-EK 250 res
    [XG] Xtreme Gamer
    May 2008
    Upper Peninsula
    I'm looking more for silence and looks anyways, if I could get 3.2-3.6GHz, I'd be happy. Do I need the shroud for the feser?
    I am Xtreme
    Dec 2008
    Hollywoooooood, CA
    You don't need a shroud, but if you like the looks, rock on.
    i7 965 | Rampage 2 Extreme | Asus 4870X2 | 6gb OCZ BLADE 7-8-7-20 | 4 OCZ SSD V2 in RAID0 |
    1 VelociRaptor 300gb | 1 WD Caviar Black 1TB | Tagan ITZ 1100w PSU | LG 6x BluRay Burner | 52" Sony Bravia LCD
    Homemade SS Phase Change | Kayl Custom Lineset
    My Case - Treasure Chest Build Thread : http://www.xtremesystems.org/forums/...d.php?t=218115
    [XG] Xtreme Gamer
    May 2008
    Upper Peninsula
    I've seen pictures of Cosmos's with a triple rad, but no explination on what they did. Could I fit one in there without modding? Or is there any other spots where I could place another rad? Thanks for your time.
    I am Xtreme
