The date was pushed back in case anyone didn't get the email.
Good thing too, because I've only done synthetic benchmarks so far, still need to do some real world testing
You can install 16Gb of DDR2 on one 9010, set the jumper to dual mode, and you will have 2x 8Gb "disks". When RAID0'd you will get the same capacity you have now (16Gb) but double the performance.
If you get a 2nd unit, you repeat the same and end up with one 32Gb disk, comprised of 4x 8Gb drives in RAID0 and 700Mb/sec speed
i5 660 / Asrock P55M Pro / Ripjaws / GTS250
Really? In RAID-0 performance on mine actually decreased quite a bit except for stuff where there is large, sequential I/O. Windows boot and such slowed down by average of ~2 seconds. Windows install also increased. Maybe it's my RAID controller. I might switch it over to my Areca ARC-1220 and see how it performs then instead of using SB750 RAID. Frankly speaking though, the results were as I expected with RAID-0 increasing task time for stuff where it's lots of little bits of I/O.
Particle's First Rule of Online Technical Discussion:
As a thread about any computer related subject has its length approach infinity, the likelihood and inevitability of a poorly constructed AMD vs. Intel fight also exponentially increases.
Rule 1A:
Likewise, the frequency of a car pseudoanalogy to explain a technical concept increases with thread length. This will make many people chuckle, as computer people are rarely knowledgeable about vehicular mechanics.
Rule 2:
When confronted with a post that is contrary to what a poster likes, believes, or most often wants to be correct, the poster will pick out only minor details that are largely irrelevant in an attempt to shut out the conflicting idea. The core of the post will be left alone since it isn't easy to contradict what the person is actually saying.
Rule 2A:
When a poster cannot properly refute a post they do not like (as described above), the poster will most likely invent fictitious counter-points and/or begin to attack the other's credibility in feeble ways that are dramatic but irrelevant. Do not underestimate this tactic, as in the online world this will sway many observers. Do not forget: Correctness is decided only by what is said last, the most loudly, or with greatest repetition.
Rule 3:
When it comes to computer news, 70% of Internet rumors are outright fabricated, 20% are inaccurate enough to simply be discarded, and about 10% are based in reality. Grains of salt--become familiar with them.
Remember: When debating online, everyone else is ALWAYS wrong if they do not agree with you!
Random Tip o' the Whatever
You just can't win. If your product offers feature A instead of B, people will moan how A is stupid and it didn't offer B. If your product offers B instead of A, they'll likewise complain and rant about how anyone's retarded cousin could figure out A is what the market wants.
my review will be posted today in the xtreme reviews section. Time to get cracking on it. dammn procrastination .
i5 3570K@ 4.8GHz 1.32v, 32GB Gskill 1866, Gigabyte g1 sniper m3
HD7970@1125/1575 stock voltage
1TB F1+2*128GB Crucial M4
Silverstone 450w, no case
2560*1440@120Hz overclocked catleap
Steelseries G6v2+5600dpi modded logitech trackball
Does anybody have a setup to compare and to create a review about ANS-9010 versus ANS-9010B in single and RAID mode? Would be interesting to see those two units competeing against each other. I have a freaky thought that the cheaper units in RAID mode would won - don't ask why. (Haven't touched by myself-not sold in EU yet )
I think you would find performance to be identical, with only the maximum size of the disk varying (6 dimm slots vs 8). There's no difference in speed between having 1 and 8 sticks of ram in the 9010, so having 6 sticks in either system should be the same too.
I doubt the models have any physically different components, so I am making that assumption in my answer.
Damn it I had more ram I'd enter but I only have 2 gigs and no review writing experience.
I've had the damnedest time getting consistent results. I have to reboot the damn machine to clear out the disk cache.
Rule 1A:
Rule 2:
Rule 2A:
Rule 3:
You seem to have problems running much of anything :p
Motherboards mainly. heh I've blown through my fair share of them, but I blame build quality. Most of my failures were MOSFET related. And I don't think you can blame the Catalyst problems I've been having on me either.
Rule 1A:
Rule 2:
Rule 2A:
Rule 3:
My review can be found at: http://forums.primelogic.com.au/inde...pic,758.0.html
I decided I'd be special by posting elsewhere. Seems like I'm not the only one People can pm me here as well for questions or testing requests.
It's a bit long. I felt it was justified. There's a lot to discuss
Cheers,
gbg
My idea was to use software raid to get it to show up as a single logical volume, then use vmware to effectively boot from the software raid and do real world tests within vmware ,but the performance hit isn't negligible. I'll have to do the tests with a real os.
this will take another day, sorry.
edit: http://www.xtremesystems.org/forums/...80#post3618180
I'm quite disappointed by how many people didn't do the review... there are 4 links here, and we know Particle's is on the way.
I really hope 5 people didn't take the unit and run. That's quite awful if true
I'm quite disappointed by how many reviewers (including TechReport) managed to get the same scores with the ANS-9010 in dual mode, as in single mode.
I mean, come on!
It does depend on what theyre testing. Read/writes go up, IOPS/seeks stay the same. The benchmark application also may not work (I found at least 2 that didnt) on such fast drives. If the benchmark app screens the actual speeds behind a silly number (eg: if you couldn't look into individual speeds in pcmark you'd just get a meaningless end number) it will also hide that the app is failing.
Mine was posted at OCF on the 31st:
http://www.ocforums.com/showthread.php?t=594189
It isn't in the review, but I ordered some Fujitsu 15K RPM SAS drives that I'll be comparing the ACARD to as well. Testing will start tonight, actually.
Folks, RAID-0 isn't a magical thing that will double all performance. It's going to matter when you're doing lots of large, sequential I/O but not much of anything otherwise. For real-world usage like boot drives and program loads, RAID-0 will probably even slow you down versus a single drive.
Rule 1A:
Rule 2:
Rule 2A:
Rule 3:
Any word on who ever won the second 9010 + eSATA enclosure? We must be a bit past the extended evaluation day by now.
Dual CCIE (Route\Switch and Security) at your disposal. Have a Cisco-related or other network question? My PM box is always open.
Xtreme Network:
- Cisco 3560X-24P PoE Switch
- Cisco ASA 5505 Firewall
- Cisco 4402 Wireless LAN Controller
- Cisco 3502i Access Point
Xtreme Network:
So everybody got their unit apart from me despite being sent a email just before christmas saying I'd be getting some to test, thats great. If I had some kind of notification then fine, as I didn't, this company now = blacklisted in my books.
"Prowler"
X570 Tomahawk | R7 3700X | 2x16GB Klevv BoltX @ 3600MHz CL18 | Powercolor 6800XT Red Devil | Xonar DX 7.1 | 2TB Barracuda | 256GB & 512GB Asgard NVMe drives | 2x DVD & Blu-Ray opticals | EVGA Supernova 1000w G2
Cooling:
6x 140mm LED fans, 1x 200mm LED fan | Modified CoolerMaster Masterliquid 240
Asrock Z77 thread! | Asrock Z77 Extreme6 Review | Asrock P67 Extreme4 Review | Asrock P67 Extreme4/6 Pro3 thread | Asrock Z68 Extreme4 thread | Asrock Z68 Extreme4 Review | Asrock Z68 Gen3 Thread | 8GB G-Skill review | TK 2.ZERO homepage | P5Q series mBIOS thread
Modded X570 Aorus UEFIs
