I was wondering if anyone has dimensions or links with dimensions or CAD files or any information on building a Blackops northbridge top.
I have an interest in building a couple custom non aluminum tops.
CPU: Intel Core 2 Extreme QX9650 Yorkfield
Motherboard: Foxconn Blackops X48
Memory: 4G 2x2 OCZ Reaper DDR3 1800 (PC3 14400) 8-8-8-27 1.9v
Hard Drives: 2 x W.D Raptor 150GB (OS, games, apps) RAID0
Video Card: XFX Black Edition 9800GTX @ stock frequency (760 core / 2280 memory / 1900 shader)
Case: CM Cosmos S
PSU: Corsiar 620HX
WC : Custom Water
Optical Drives: Nec 3550 dvd burner
OS: Gentoo GNU/Linux amd64 | Windows Vista Ultimate 64-bit
Odds/Ends: Razer Diamondback Mouse - Happy Hacking Keyboad Pro2 - RME pro audio card. FreeBSD UNIX servers and laptop when I'm not gaming!
Contact Iandh. He is making some for Petra's. He just sent a couple brass tops and acetal ones will be following shortly.
Heatware: Broken
Ebay Feedback: Brokennails
Ian's the man! I have one of the brass tops coming in the mail.
Asrock Extreme 4 | 2600K | 16G G Skill | Powercolor LCS 7970 | PCP&C 910 Silencer | Crucial C300 + Intel X-25V + Raptors | D-Tek Fusion v2 | Swiftech MCR Drive 360 | HP LP2475
Yeah, I am guessing all four went so fast, which is why I never even saw them on the sight. How much was it? I am guessing the acetal's will be cheaper.
Heatware: Broken
I dealt direct with Ian. I approached him based on some dead end threads from July. Send him a PM. He'll fabricate whatever you would like.
Lucky bastard. I tried that route too. I wanted an Acrylic top months ago. Now looks like I will settle for acetal or just ditch this board and go with a X58. Have not decided yet.
Heatware: Broken
lol......why not just get a separate northbridge water cooler? I think that the 3n1 cooler comes completely off, leaving just a copper block over the heat pipes. Be a hella lot cheaper than geting a whole new rig.
Can make acrylic top for it if I had the cad file. Have access to a milling machine here.
Case: CM Cosmos S
PSU: Corsiar 620HX
WC : Custom Water
Dang, Petra's had some brass tops in stock so ordered one. Glad I did, especially after that thread in the liquid cooling section with the horribly corroded Blackops top... I can understand wanting to save a buck but this was a little ridiculous. Can't wait to see what mine is like. I was using Innovatek protect so hopefully it isn't too bad.
As for ditching this board, I think I solved(finally) this boards issues, but still would like to go X58. Just can't afford it right now.
Heatware: Broken
Some of Ian's handiwork! It did a real nice job with those. Let me know how you make out with it. I haven't bolted mine on yet, too lazy at the moment.Petra's had some brass tops in stock so ordered one.
Well, fits like a glove. The stock screws have just enough thread to tighten down as the brass top doesn't have countersunk holes like the stock crappy aluminum one. Great work though! I was surprised my top looked as good as it did. Then again Innovatek fluid is pretty good with mixed metals. Looks like it was starting a little on the threaded part where the fittings scraped away the anodizing... Nothing too bad, but given enough time............
Heatware: Broken
That's great to hear Broken. Not so good about the stock top. How are your temps at what volts? What radiator are you using?
