quiestion of a possible new build
Hi all,
I am thinking of doing a new build from my leftover parts and this is what i have:
qx6800
8800 gts
swiftech mcr220
swiftech mcr120
coolit freezone
possibly 2 pumps, mcp655 and mcp355
i am doing a cpu and gpu loop and i want to add the freezone to the loop, so is it worth it to add the tecs on the coolit system? and if it is how do i plumb this loop?
Regards.
never mind, i got the answer
the pictures you posted is the newer version, the Freezone Elite, im talking about the older one, and yes i want to use it as a chiller, but i found out that its aluminum so its a no go unless some one can prove its not alu?
here is a link to the one i have:
http://www.bjorn3d.com/read.php?cID=1055
- You may not post replies
- You may not edit your posts
Forum Rules
