Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: When In Doubt....
    Xtreme Cruncher
    Feb 2005
    Cleveland, Ohio
    When In Doubt....
    Overclock.
    C2D e6600 @ 3ghz was getting @ most 6.6MCeM's
    then i decided i was tired of getting slaughtered, so i decided that overclocking was my friend
    e6600 @ 3.4 now getting 7.7MCeM's
    it'll probably level off around 6.9 when all is said and done.. but wewt for OC'ing
    toobad it takes 1.5 Vcore to reach 3.6ghz
    May 2005
    Camping your spawn :)
    Ouch I do 3220 @ 1.36
    What week is ur 6600?
    I wish i had a decent enough board to let me go higher
    Im 1:1 460 which is mobos fsb wall..
    Join the XS WCG team and do your part to help save the world..
    ^^^Click here to start folding for the soon to be number one team in the world..^^^
    Main rig: Gigabyte DS3/6300@3.2 7950 GX2/Server:Expert/165@2.9/PCI vid/Wifes:ASrock Dual SATA2/3800@2.4/X800XTAIW/Kids:165@2.7/X850XTPE
    "A computer beat me in chess, but it was no match when it came to kickboxing"
    -Emo Philips
    Xtreme Cruncher
    Feb 2005
    Cleveland, Ohio
    after a while of running @ those clocks it has tailed off, now i am just over 6.0 CeM's
    however i restarted the svc. and now im up again @ 7.4
    Dec 2005
    UK
    Mine tails off too.
    I find a restart about once a week keeps it on top.
    is that 7.4 Cems per service?
    I'm getting around 5.5 to 6 per service on my 6300 @3200 mhz
    SOB Crunchers.
    E6300 & DS3 @ 487 X 7 3409 mhz 1.4125V Ninja
    805D & P5WD2 Premium @ 194 X 20 3885 mhz 1.40V WC
    P4 3.2 & P4C800E Dlx @ 239 X 16 3824 mhz 1.40V XP120
    Moderator
    Mar 2006
    Hmmm... tailing off is very strange indeed. Never experienced it, although it does happen when I'm running other stuff on it... Guys... Just an idea... is your rate changing anything to to with finishing one block and starting another? Cos you do know that different k/n pairs give different rates.
    Dec 2005
    UK
    Yea, don't think it's that though.
    If you just shut down and restart, carrying on with the same numbers you instantly get a better output.
    SOB Crunchers.
    Mar 2006
    Puerto Rico
    I better start reading my OC for Dummies Book. Diablo may need some OCing
    Space for Rent
    Xtreme Cruncher
    Feb 2005
    Cleveland, Ohio
    yup here is hte look at it after some overnight running.
    still going strong.
    Dec 2005
    UK
    Are you running 2 services or 1?
    I Imagine that's 2, Still a fair increase over what I get at 3200 though.
    SOB Crunchers.
    Xtreme Cruncher
    Feb 2005
    Cleveland, Ohio
    Quote Originally Posted by PFOUR
    Just one, the other core is running a secret special surprise for some people
    Xtreme Cruncher
    Mar 2005
    Houston
    Quote Originally Posted by bullet2urbrain
    pump that voltage up, i have 1.525 going through my E6400 with a big typhoon.
    I was thinking of upping it to 1.575 or 1.6. These cpu's can handle quite a bit of heat, but most people are scared and still using the 90nm AMD standards regarding temps.
    i currently load at 60C with the BT and use to load at 65C with the stock cooler.
    i have not heard of a single person burning up their C2D yet do to overheat. My next stop will be 70C at full load.
    OC that bad boy to the MAX
    312 Xeon Threads + GTX 1080 + GTX 1070 + BFL Monarch 700
    Mr. Boardburner
    Jun 2005
    the Netherlands
    Quote Originally Posted by KaptainBlaZzed
    Intels can take up to 80C without too much trouble (talking from experience). Never blew any CPU due to overheating yet... I have even seen one at 120 for a split second when the cooler wasn't mounted correctly, and the poor P3 is still working fine
    Main rig:
    CPU: I7 920C0 @ 3.6Ghz (180*20)
    Mobo: DFI UT X58 T3eH8
    RAM: 12GB OCZ DDR3-1600 Platinum
    GPU/LCD: GeForce GTX280 + GeForce 8600GTS (Quad LCDs)
    Intel X25-M G2 80GB, 12TB storage
    PSU/Case: Corsair AX850, Silverstone TJ07
    Xtreme D²OL Watch Dog
    Feb 2005
    Canada
    I blew one of my overclocked Xeons on the weekend. A 2.4Ghz running at 3.8Ghz with 1.6v. The other one in their still works fine so not sure what the problem was it’s been running fine like that for over a year… pisses me off!! Not going to be easy to find another one that will do 3.8Ghz again.
    Xtreme Cruncher
    Mar 2005
    Lancaster, PA
    Coretemp is showing 69c & 70c running WCG and DPAD. This is with 1.6625v on watercooling. Haven't had any noticable heat-related problems. Once I add the x1900XT I'm getting from AFI to the loop, I think the temp might go up a bit, since it's all on a PA160.
    A wolf in wolves clothing.
    Xtreme Cruncher
    Feb 2005
    Cleveland, Ohio
    Im one of those people, i still regard 50* C as the absolute max i want my CPU.
    and its close right now @ 49* C Fully loaded.
    Perhaps if im feeling frisky :P i'll up it and see what i can get to...
    65nm vs. 90nm still worries me.
    Mar 2006
    Puerto Rico
    Who will like to teach an olde phart like me how to OC Diablo?
    Space for Rent
    Xtreme Cruncher
    Feb 2005
    Cleveland, Ohio
    Jose,
    Someone has a very profound quote in their sig around these parts and me thinks its Ozzimark.
    In overclocking he who tries the most things wins.
    Basically keep temps low ( and with LV_DD's WC'ing) and keep clocks high.
    im more than happy to help but i dont really konw how to describe starting from scratch.
  18. #18
    V3 Xeons coming soon!
    Nov 2005
    New Hampshire
    Overclock.
    My DX3600 maxxed at 8.3mil...Weedsqueezer had a 6600 at 3600-3700 and was showing 12 mil..scary!
    The XS WCG team needs your support.
    A good project with good goals.
    Come join us,get that warm fuzzy feeling that you've done something good for mankind.
    Quote Originally Posted by Frisch View Post
    If you have lost faith in humanity, then hold a newborn in your hands.
  19. #19
    Mar 2006
    Puerto Rico
    Jose,
    Arg!!! I know what need to be done, it is the HOW ... Hoiw does one plays with the clocks?
    I feel so obsolete.
    Space for Rent
  20. #20
    Xtreme Cruncher
    Mar 2005
    Houston
    Quote Originally Posted by Jose
    I feel so obsolete.
    read this for starters.
    http://www.hardforum.com/showpost.ph...89&postcount=2
  21. #21
    Xtreme Cruncher
    Feb 2005
    Cleveland, Ohio
    Quote Originally Posted by Movieman
    Dave: Actually showing 12million? or a combined 12million?
    sheesh, if i cant get each core to 12million it may just be worth it to dump my "side" project for some SoB Stomping.
  22. #22
    Nov 2005
    New Hampshire
    combined..
  23. #23
    Xtreme Cruncher
    Feb 2005
    Cleveland, Ohio
    combined..
    Phew... cuz right now combined I'd be sitting at just over 14, approaching 15 with a restart.
    You had my young heart beating pretty darn fast Dave.
  24. #24
    Nov 2005
    New Hampshire
    told ya those darn ho's are monsters!..NJKID saw a combined of 18+ mil on Clark
  25. #25
    Xtreme Cruncher
    Feb 2005
    Cleveland, Ohio
    hmm ima need some better cooling for that....
    Dave: YHPM
