Results 1 to 21 of 21
Thread: PM Tracking
    Xtreme Enthusiast LutaWicasa's Avatar
    Jun 2002
    Chicago
    PM Tracking
    PM tracking isn't working. Click on it and it dumps me back to the "Inbox".
    Heat
    Gimme back my bullets.
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    Easy fix, PM tracking was turned off for some reason. I saw the option and didnt know what it did so I left it alone.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Jun 2002
    Chicago
    So.........will you re-enable it? It makes things much easier when I know someone has received a message but opts to ignore it
    Heat
    Nov 2001
    Wichita, KS
    Agreed!~! Makes things alot nicer indeed.
    Jun 2002
    Chicago
    Still not working
    Heat
    Nov 2001
    Wichita, KS
    Still not working
    Yup, what he said?!
    Jun 2002
    Las Vegas
    Looking into it more, its a feature I never used and didnt know that it was still broken. In the general config PM tracking is enabled.
    Any ideas Jbell?
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Jun 2002
    Saskatoon, Saskatchewan
    Hmm.... mine appears to be working.
    AXP1700+ JIUHB 0302 @ 2400MHz - TEC-Watercooled in The Skyscraper
    ABIT NF7-S , Sapphire Radeon 9500 Pro, 1.5GB XMS3200C2
    XS IRC channel: irc.quakenet.net #xtremesystems
    www.ocfaq.com
    Jun 2002
    Chicago
    Geez...........I sure wish mine was
    Heat
    Jun 2002
    Yeah, I tested it. I sent a PM to someone this morning, checked the PM tracking right after, and it showed it sent, with e-mail notification sent, and not viewed yet. So I'm guessing it's working.
    Perhaps in the user options somewhere you can turn it on and off?
    www.ocfaq.com
    Jun 2002
    Chicago
    If it is, be damned if I can find it. Been through everything I can find that pertains to PMs.........nada. Still dumped back to "Inbox" when I select "Message tracking".
    Heat
    Jun 2002
    Las Vegas
    Ok, made some changes to "troll hunters" so you cannot be denied PM tracking by recipiant settings.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Jun 2002
    Chicago
    It's not a problem of receipts being denied. I am unable to track, period
    Heat
    Jun 2002
    Las Vegas
    I am able to track everything.
    Ill keep looking
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Jun 2002
    Las Vegas
    Im gonna switch you over to a admin to see if the problem goes away. Narrow the problem down some.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Jun 2002
    Chicago
    Still being dumped back to the "Inbox". Looks like the forums time is screwed too. Reading an hour early?
    Time is now 9:25
    Heat
    Jun 2002
    Las Vegas
    The server is off by an hour.
    K, ill check some more stuff out since that didnt work
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
  18. #18
    Jun 2002
    Las Vegas
    click "modify" under "user groups" and click edit next to "troll hunters" You will see the optin for PM tracking.
    Still digging around.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
  19. #19
    Nov 2001
    Wichita, KS
    Just pointing out that this was a problem I had quite some time ago here. I had bugged Joe until it was fixed. I personally have no clue what the problem was, but he got it straightened out. Id give him a buggers again and see what he can do.
    BTW, I am also being dumped back into the Inbox, no message tracking for me either.
  20. #20
    Jun 2002
    Chicago
    Oh man, am I embarassed
    If I use the "jump to folder" to access message tracking, I still get dumped back to the inbox. But.......if I click the button for message tracking at the bottom of the PMs page........works a treat. I never even noticed that button
    (I'll just quietly slink away now.....)
    Heat
  21. #21
    Nov 2001
    Wichita, KS
    Aye same here?!
    Which is odd in its own right.
    Before, some time ago, JBell had to do something to get it to work the way Luta was saying.
