I think this is a good idea, someone out there must of already tried this. Im considering water cooling but it will get exspensive, like $300 for a good system including White Water.
I was going to get a Dorm Refrig to put the rad, res, and pump in there. But then I was thinking about condensation and then I thought WHY NOT make the Frig my computer case. Everything gets cold, SB, NB, CPU, Memory, all chips, everything. I would use round IDE cables and put cdrom and dvd burner outside of frig. Everything else inside. Power supply could go outside also if necessary.
??What you think, dont have to worry about condensation and only cost $78.00 for a brand new Dorm Frig at Lowes! ??
Thats another thing I found out. I was calling Pawn shops and Applaince stores and newspaper, evryone wants forty dollars or more for a used Frig. Lowes has them brand new and they use 285-321 Kwh per year. Thats 26.11 per year based on 8.5 cents per kwh. Keeper said that his uses $10 per month.
Sproket
