I have tried almost all combinations of 1, 2 and 4 dimms installed. I have tried 2 dimms in both slot combinations and a single dimm in any of the 4 slots available. No change.
I am on the official 0704 bios. On the first POST after I clear the CMOS (the only time the board will actually POST) then I can boot into windows. From there I ran the Asus update tool and updated the BIOS to 0704. However...after reading that any windows based bios updating tool can cause issues, I then flashed again using the EZ Flash tool from within BIOS, same result.
Just to recap the issue so there isn't any confusion:
1. Immediately after clearing CMOS, the board will POST and take me to a screen that basically says:
"Please enter SETUP to recover BIOS settings.
Press F1 to enter SETUP
Press F2 to load defaults and continue"
2. If I press F1, I can get into the BIOS (hence how I used the EZ Flash tool), but once I save and exit...no POST.
3. If I press F2, the pc will continue to load windows and the computer seems to function great (7 instances of memtest, 0 errors, overnight). Once I reboot/restart the pc, no POST.
Thanks for the voltage settings...I'll try those and see if it makes any difference tonight!
