yeah, april... but what do you think of those connectors? thei will interfere with heatsink or waterblock maounting... :(
simple.. :D heating up your soldering iron..
Has anybody had any difficulty getting a 1.8 dothan to run in the AOpen mobo?
I swapped one for my 1.5 and keep getting a CMOS error ('Sumcheck' i think) and then it hangs in the post screen. Any ideas?
EDIT: Bit more info: I have been running a 1.5Ghz dothan in the AOpen mobo at 2.25 (with socket wire mod). Just got a 1.8Ghz one to get a higher multiplier to push things further. I updated to the latest BIOS and set everything to default. When my machine boots up it with the 1.8Ghz it will sometimes give me a post screen, other times i have to press Delete to get one. It recognises the CPU as a 1.8 and shows it as (18x100) but then gives me the CMOS error. When i press delete to get to the BIOS it reboots. :confused: Tried this with and without the socket wire mod.
As soon as i put the 1.5 back in it works fine.
Originally Posted by Cyprio
have you cleared cmos after putting the new cpu in?
Heya,
Can anyone here confirm that the various on-board hardware (audio, network, promise s-ata) works for all stable FSBs when fixing the AGP/PCI lock to 66/33 MHz using the beta version of ClockGen for the AOpen 855 board?
I don't want to buy another audio card, as I'm building a compact system, and I'm afraid of how an increased PCI speed could affect the other parts of the system. Also, I'd like to use my AGP card without glitches/lockups.
YUP.Quote:
Originally Posted by 2fink
Asus makes two S478/915 mobos, P4GD1 and the cheaper P4GPL-X. I wonder if they will work with the adapter...Quote:
Originally Posted by Kunaak
Albatron makes two S478/915 mobos. There are probably more of them.
Has anybody managed to change multiplier? Is multiplier changeable? If you can change it, post it here... i would like to see how many... :D
because i "cannot" change multi.. WON'T LET ME...
However, I'm getting some deep sh#t (meaning very good) performance at impressive 125~ 130FSB lol... Getting 31,59x 3dmark score on an air cooled dothan at default xtpe clock is very heavily impressive. :D
I really can't complain low FSBs. It's way too fast already. I don't want high FSBs... :D
this is my 24/7 speed - a 15x multi on an 1800MHz Dothan
http://www.xtremesystems.org/forums/...id=26335&stc=1
There is this one...Quote:
http://www.newegg.com/app/ViewProduc...170-127&depa=0
But its the only one I have ever found. Looks like a decent board.
EDIT:
Hmm... I see there are some ASUS boards as well. These might be better for overclocking...
wow, what a strange board :shrug:Quote:
Originally Posted by executor252
Ummhmm. Supports DDR 1-- do the ASUS 478/915 boards use DDR1 or DDR2?Quote:
Originally Posted by charlie
I am biased towards a board that will run DDR1 for use with a Dothan :D
Yes - you can overclock and keep the sound working - only with the clockgen tool though... If I overclock using the BIOS it craps out (funny that AOpen can't get the locks working but someone else can). I have some graphics pauses at some FSBs but have had the audio working fine right up to 180MHz (board or CPU isn't stable above that - I'm running a Banias CPU I bought cheap on ebay)Quote:
Originally Posted by mikael_j
Have managed to pick up a 1.7ghz Dothan 2mb cache sl7ep cpu for £52. A great bargain price, but what is my best motherboard option? Should I go for the Aopen which I get for £149 or the DFI which will cost me £179. Looking to get the cpu stable about 133mhz so will running at 2100-2200mhz stable. I need the pci lock as I will be using a SATA maxtor hard drive and I know these like to be run bang on the 100mhz frequency to prevent data corruption.
Or should I just sell on the Dotan for £110+ and stick with my Winchester 3000+.
Rob H
Okay, that'd be fine with me. I'm going to hold off doing that 'til the Soltek 855GEI-FGDR is released -- if it has a working AGP/PCI lock I'll get that instead. (I'd need to port ClockGen, or actually write something that works similarly, for the operating system I use, so I'd rather not mess with it if I don't have to. :)Quote:
Originally Posted by malfunction!
But thanks for the info!
hey..
I have Aopen i855Gmem-LFS and I havn't understand how can i lock the AGP/pci ratio..
you said the bios locking isn't working .. but i can't see any locking in the clockgen either.
:confused:
venom, i beleive there is an updated (beta?) clockgen available somewhere (you may have to google), i'm not sure where
I searched all google :|Quote:
Originally Posted by cirthix
if someone knows where can i find it it will be great. :]
Just out of curiosity, (I know this thread is mainly dedicated to desktop OCing of Dothans), I am using clockgen for the Intel 845 (CY-something PLL) chipset on my laptop. The PCI/AGP frequency control is not present. I assumed this was a PLL issue, that this PLL cannot lock the AGP/PCI bus frequency. Just for kicks I checked cpuid.com, and it says there that "Some versions of clockgen do not support" AGP/PCI freq lock. Does this mean that there is the potential for a future release of clockgen for this PLL to support AGP/PCI freq lock?
It doesn't really matter since my laptop, being thin, lacks the cooling capacity to handle a large overclock (at 2Ghz CPU reaches 72C load-- not good), but it would be nice to squeeze 1.8 out of it (the CPU and cooling solution can handle this but video chipset can't render in 3d artifact-free anymore, likely due to the 125MHz FSB....).
So is the lack of AGP/PCI lock a software issue or does the PLL not support it at all?
Look back a couple of pages in this thread, sheesh.Quote:
Originally Posted by Venom21
In this thread someone said that there is a clockgen that can lock the agp/pci ratios but the only clockgen I found was the regular agp lockless one.Quote:
(i'm looking for a one that has also the agp ratio like on the DFI's clockgen).
And I really don't think i deserve a "sheesh". (you could just give me the link instead of that..)
hey all,
any new mobo's out?? Thinking of getting back in the Dothan pool when the water get's warmmmm...........
yeah, I am thinkking of going in there when Ct-479 is out :)
The URL to the beta-version of ClockGen that can indeed lock the AGP/PCI clocks on AOpen mainboards was posted in this thread a couple of pages ago. I cannot give you the link, because I have other things to do than searching for it for you. You will find it, however.Quote:
Think thats the one mate http://www.cpuid.com/download/CG-ICS950813.zip its on page 29.Quote:
On a side note I picked up a 1.5g dothan off ebay for £46.50 then thought what the hell and ordered the aopen today. Cant wait to see what it'll do
:D
