the "über" cards from nv since the 7xxx series allways where "near EOL" products, milking out the last drop of the enthusiasts. :D
I've been using a single 8800GTX @ 630/1900 since nov '06 and now I'm considering an upgrade. This card still handles all games with ease, but I'm thinking about picking up a second one for SLI. But now that the 9900GTX is nearing, do you think a single 9900GTX would be able to outperform dual 8800GTX's @ Ultra speeds? Or should I just sell the 8800GTX (nvidia reference card) and wait for 9900GTX?
tough decisions...
try to get rid of that 8800 gtx as quickly as possible (more money) and buy a gtx 280 (faster than sli, no issues), if youve got 400$ to put onto the 150-200$ youll get for the 8800
edit: lol, those prices on ebay are so ridiculously high, so you can expect even more
Just put the card on ebay, 9900GTX here I come! :D
I'm willing to bet my Seasonic S12-500W will run the E8400 and the GTX 280 just fine, I ran a RTHDRBL + Prime95 torture test with a 3.4ghz 1.4v Q6600 and overclocked 8800GTX for a few hours last year with ZERO issues. Wattage requirements are grossly overstated to get you to buy :banana::banana::banana::banana: you don't need. My E8400 is using 100-150W tops + another 250W from the GTX 280 will put it right at peak of my PSU's efficiency curve. Quality>quantity.
Though I think you are correct in your situation (solely b/c of the brand), there are other things running aside from your CPU and GPU on teh 12v rail, the mobo for an example. Not to mention there are items on the 3.3 and 5v that, in a lot of PSU's, take away from the max output of the 12v rail.
PS, Hi neighbor!!!
RV770 only can compete with G92b 55nm, because we know GT200 will
be a Monster both in graphs/performance quality and Hot as hell... smells like
barbecue to me, hope not.
not really, but it's obvious amd's offer becomes mid-end with GT200 on the road
exception for the Dual RV770 of course.
old stuff check out: http://www.nordichardware.com/news,7765.html
Aqua Computer Launches Aquagrafx G200 for GeForce GTX 280 and 260 Video Cards
With NVIDIA's next generation video cards just around the corner, German water cooling expert Aqua Computer has decided to launch a video card water block that will fit on reference NVIDIA GeForce GTX 280 graphics cards. Supposedly, the water block will suit on GeForce GTX 260 cards too, but this information is not confirmed. Just like every other Aqua creation, the Aquagrafx G200 is a full-cover all copper block with G1/4" connectors and channels optimized for very low flow resistance. Now we only have to wait for the cards to come, until then this GPU block is not applicable. No word on pricing and availability yet.
source: Aquacomputer
I guess you all allready know that GT200 will be GEFORCE GTX 280 and 260 and G92b actually will be 9900 in 55nm
500 watt liberty is a decent PSU... just let him try it before going broke on wattages... I bought a Galaxy 1kw PSU to run SLI on 8800GTX , think the demand in wattage was so overrated, as that rig also ran fine powered by an Enermax Liberty 620... we will have to see when the reviews pop up what the real demands are... in case of instability it might be his PSU that borks out... only time will tell
and that's again one sexy waterblock there, me droooooooooooools
Repost repost repost.
http://www.xtremesystems.org/forums/...d.php?t=188698
http://www.xtremesystems.org/forums/...d.php?t=188821
http://www.xtremesystems.org/forums/...d.php?t=188859
Also, where do you get your info that rv770 will loose, benchmarks? Insider?
I might do what someone has already mentioned and avoid the inital price gouge. No pressing need here. :yepp:
I am building a new system around late June so i'm going to get owned by the price gouge! :(
Hopefully the GTX 260 will be affordable. I think 350-400 euro ($550-630) would be a good price
*edit*
LOL Scroll down for official GTX 260 specs!!!!!!!
http://www.sunocoinc.com/NR/rdonlyre...oco_260GTX.jpg
http://www.sunocoinc.com/Site/Consum...noco260GTX.htm
*Warning* the INQUIRER *Warning*
http://www.theinquirer.net/gb/inquir...0-280-revealed
LMAO, they prefaced their prediction with "quite likely" then stated the 280 would "lose very badly" uncertainty and strong predictions are typically mutually exclusive... Still, I'll believe it when I see it. If true no jagon would buy a $600 card that gets it's arse kicked by a $350 card.Quote:
The 280 has 240 stream processors and runs at a clock of 602MHz, a massive miss on what the firm intended. The processor clock runs at 1296MHz and the memory is at 1107MHz. The high-end part has 1G of GDDR3 at 512b width. This means that they are pretty much stuck offering 1G cards, not a great design choice here.
The 280 has 32ROPs and feeds them with a six and eight-pin PCIe connector. Remember NV mocking ATI over the eight-pin when the 2900 launched, and how they said they would never use it? The phrase 'hypocritical worms' come to mind, especially since it was on their roadmap at the time. This beast takes 236W max, so all those of you who bought mongo PSUs may have to reinvest if they ever get three or four-way SLI functional.
The cards are 10.5-inch parts, and each one will put out 933GFLOPS. Looks like they missed the magic teraflop number by a good margin. Remember we said they missed the clock frequencies by a lot? Here is where it must sting a bit more than usual, sorry NV, no cigar.
The smaller brother, aka low-yield, salvage part, the GTX260 is basically the same chips with 192 SPs and 896M GDDR3. If you are maths-impaired, let me point out that this equates to 24 ROPs.
The clocks are 576MHz GPU, 999MHz memory and 896MHz GDDR3 on a 448b memory interface. The power is fed by two six-pin connectors. Power consumption for this 10.5-inch board is 182W.
This may look good on paper, but the die is over 550mm, 576 according to Theo, on the usual TSMC 65nm process. If you recall, last quarter NV blamed its tanking margins on the G92 yields.
How do you fix a low yield problem? Well, in Nvidia-land, you simply add massive die area to a part so the yields go farther down. 576 / 325 = 1.77x. Hands up anyone who thinks this will help them meet the margin goals they promised? Remember, markets are closed Monday, so if you sleep in, no loss.
The 260 will be priced at $449 and go up against the ATI 770/4870 costing MUCH less. The 280 will be about 25 per cent faster and quite likely lose badly to the R700, very badly, but cost more, $600+.
Sounds like a ton of biased bull:banana::banana::banana::banana: but wait that's all the Inquirer publishes.
Unfortunately that will not happen.
And with mid to high AA/AF levels, the gap will be even bigger.
Considering that a gamer who gets 350$ out of his pocket wants to play with full details and AA/AF, the high end sector is green once again.
I'd really like ATi to come really close to or even surpass nVIDIA this round ( when I game I game with AA/AF, my eyes are too picky :D, so yes, I'm talking about AA/AF enabled ) for the sake of healthy competition & our pockets.
HAHAHAHA. Anyone else notice this?:rofl::rofl::rofl::rofl::rofl::rofl::rofl:
D for DUMB@$$! That equates to 28 ROPS as nvidia's ROPs are directly related to the memory controler, meaning 448/64=7 clusters of 4 ROPs, which means 28 ROPs.:rofl::rofl::rofl::rofl:Quote:
Ohh inquirer, you never fail to amaze me and my maths skillz (being in calculus as a 15 year old never hurts either).
Personally I think he didn't realize that the performance of the 240 gt200 shaders != to 240 g80 shaders. So if that was the case, with the law of deminishing returns, I could see him being partially right, but a core of 1296? My d9gkx can't hit that!:shakes:
Guys don't consider half of what that article says, my estimate is that judging by the folding performance of the gtx 280 (and how companies love to give out numbers no one else seems to be able to get before they launch), I'd say the gtx 280 and 4870x2 will be very close in performance (gt200 having a slight lead), probably closer than nvidia will like because of how bad their yields will be.
doesnt sound very promising, not at all
if thats true that card isnt going to have a long life...
That's possible, if it was only a 2x shader domain (can't see it being 2.5x as core clock would be too low), in which case that means the core is at 648mhz, which is far more reasonable. But if the gt200 shaders are only at 1296mhz, that means there's a chance they may not actually bring the performance boost we're expecting regardless of how much more efficient they are
Any don't worry I wasn't shooting the messenger, just farting fireballs at Charlie's left niple:D
And seriously people, please read the page before posting something, the 4xxx series thread has like 5 of the same links in some cases (just a thought)
