PS
Oh, and I don't trust myself to mod the other pump!
What about the D-Tek MAG?
Yan
PS
Yan
Not much is known about the MAG yet.
I suspect 2 of them in series will perform nice too.
I am still confused. I want something that is powerful (size is not a big issue, as the case is the Mountain Mods U2-UFO), and if at all possible a DC pump. It will be all 1/2" ID, and it will be running a DD TDX CPU WB, DD Brass MAZE4 GPU, Weapon 2-302 w/Shroud.
I was considering two MCP655, but people said that it would be too much for the 2-302.
As I said, I want something that can run off of my 600watt OCZ powerstream. I am going back to study the recomendations that the whole point of this thread is, but I can't make head nor tails of what is good. I wish there was a table, for DC pumps, and AC pumps, and which was best overall. Just a suggestion.
TIA
Yan
The Iwaki RD-30 and Panworld 20PI-Z-D are both very powerful, not very large and DC; however especially the RD-30 would be too expensive and you still won't be able to run them off your power supply (24VDC).Quote:
Originally Posted by YanBooth
The MCP655 is still the most powerful 12VDC pump, and it will perform good with a big rad like yours. If you're afraid 2 dump too much, simply take 1.
Dunno what fans have to do with this; I'll assume you mean pumps. :p:Quote:
I might make such an article this summer if I can get enough test equipment and test samples.
Yeah, I meant pumps, oops. I'm not afraid of having to MCP655's, but people say that the radiator won't be able to handle that. It only increase the water temps. by a degree or two (celsius).Quote:
Originally Posted by RaptorRaider
I am guessing all the "extreme pumps" (other than the two you provided) are still 24 volts, or not DC pumps at all.
For now my plans remain the same; 2x Swiftec MCP655, but as I said, people are saying that they will create to much heat like that.
Thanks a lot Raptor, you are, and have been very helpful.
Yan
As a sidenote, should you somehow find the heat dump to be too much after all, just use the speed adjustment dial on the back.
And yes, AFAIK all other ''extreme pumps'' use AC.
AFAIK?
So, you think the daul MCP655's would be fine?
AFAIK = As far as I know
The dual MCP655's can be adjusted with their speed dials, however I think you'll end up losing more of the flow/pressure than you will heat from these pumps by adjusting them.
Just get one, you seriously won't notice the difference getting the second and it could actually raise your temps...so why would you wanna pay for that?
See my other post, LOL. I think it is a really neat idea too.
Yan
I got 2 of thoses today (brand new) Iwaki MD-10
I also have a few MD-20, a few MD-30, 2 MD-40 and 1 MD-70
Those small MD-10 are sexy :p:
I'm waiting cpu + video block and a few rad AND this rad :D
http://www.frozencpu.com/ex-rad-34.html :banana:
md-10 is a nice pump but its incredibly underpowered. it has less power than a mcp650, 655 or AQX50Z, or DDC.
I didn't wanted to use a big 220v pump in my 24/7 silent rigQuote:
Originally Posted by MaxxxRacer
It will be installed in this :
http://xtremesystems.org/forums/atta...id=31431&stc=1
ok. as long as you know it isnt very powerful and it wont be the performance winner by any means.
I believe all the pumps Maxxx listed are 12V DC pumps -- mcp650, 655 or AQX50Z, or DDC. I also thought the MD20 comes in models to run on 120V AC.Quote:
Originally Posted by Zhy
yah the ones i listed are all DC. they are alot easier to setup than AC pumps. atleast for computer systems.
Can you tell me how you can quickly recognize which rev an MCP600 is?
I think I can remember Ancient_1 saying that an R at the end of the barcode meant rev 1 and an S meant rev 2. Or something like that.
honestly i dont remember. personally i wouldnt purchase a used mcp600. just not worth any risk. especially considering the pump is most likely about half way through its life span it would not be wise to pay more than 35USD for one.
Was thinking about buying a brand new one for $43; lost the auction while I was asleep and I've got a 50Z anyway so it doesn't really matter.
Do you think it's useful to get an MD-10K? I've already got an MD-15R and MD-20R but I can get it cheap and the heatdump is probably less than we suspected; I think it's performance might be close to that of an Eheim 1048.
well ehiem 1048 power is not very useful imo.. a TAD bit too weak.. if the deal is good enough im sure u can find some use for it but why?
Just for fun I guess.
If I don't like it, I can easily sell it for twice the price I bought it anyway: you can find these pumps brand new on ebay.com for roughly $25 (add $20 shipping for me), while they often cost more than €200 here in Europe.
The MD10's, what's their heat dump like? Lower than 50z? What's their performance specs? Also lower than 50z?
heat dump is higher than a 50z most likely (dont quote me on that as its just a wild guess) and their perforamnce numbers are about half... md15 is alot like a 50z
I think the MD10 dumps around the same wattage as the 50Z (Iwaki claims ~6W), while having a slightly higher peak flow (12LPM vs 10LPM) but has a significantly lower max pressure (5.2PSI vs 3PSI).Quote:
Originally Posted by EnJoY
This does not say all however: I think the Iwaki is more reliable and less noisy.
teh 50Z is just about dead silent when put on a neoprene pad or some carpet so id be hardpressed to agree with the quieter statement. more reliable no doubt.. the iwaki is the most reliable pump in my knowledge.. but with that said the pressure it outputs is patheticly low for our needs. its great for a low flow system that isnt very restrictive.. mcw6002 and a maze4 gpu with a heatercore.. it wouldnt get great flowrates but it would do well enough.
How's D5 compare to D4 ?
