Can somebody post good P5Q3 bios settings for around 500MHz FSB for wolfdale?
Mainly voltages and GTL settings.
I´m strugling with this board.
P5Q Dlx has backplates on the mosfets heatsinks, no warping anymore, Asus finally took care of their bad mounts... Tried with the stock heatsinks and now back on water... board is as rigid as can be :up:
I'll check Mosfet Temp Looser777 for ya (will switch off my 25 cm sidepanel fan)
Board is now $199 with free ups 3Day @egg.:D
i can get only 570 for now..
http://valid.x86-secret.com/cache/banner/374305.png
is there any ram divider works better rather than the 5:6 ? :shrug:
The screws of the mosfets heatsinks come off easilly ?
Hi guys , most of you are multiple mobo owners , do you prefer this to a 790i ? I have only had mine a week and am already looking at making a move as this baby looks like its got the right stuff .
:up:
Niz - did you find your info ? There are a few in this large thread but its looking good mate .
I played another time, this is max under air for this cpu:
http://valid.x86-secret.com/show_oc.php?id=374337
PL its ??
Performance Level
ohhh... new toys arrived :D
http://www.abload.de/img/dscf7457a32.jpg
@Chri$ch
It's great stuf there mate :)
I will get the P5Q DLX as soon as it is released here in Egypt but I will have to sell my Foxconn MARS
No new bioses ? :D
I just ordered the P5Q3 deluxe from newegg, will be here soon......ill see how it does with my Q9450 and report back.
If someone with P5Q series could have a look here and compare how P5Q series looks like compared to M2F, it would be nice! :)
http://www.xtremesystems.org/forums/...9&postcount=36
and the P5Q-E ?
sorry guys,
what are the differences between p5q pro deluxe and premium?
thanks
Got my Precious Gskills in the rig doing some tests at 1200mhz ram to determine the performance level
With 400FSB I can get 6 performance level
http://users.pandora.be/OAP/P5QDlx/400-1200.JPG
Will do 500FSB in a bit
Validation already :) Damn I love this board :up:
http://users.pandora.be/OAP/P5QDlx/4500-1200.JPG
With 500FSB Performance level 8 with ram at 1200Mhz
http://users.pandora.be/OAP/P5QDlx/500-1200.jpg
I see the vcore increase from 400x10 to 500x8 is that really required or you set it "just in case"?
Anyway, by this results we see that the P45 is not that bad as some people said and low PL is doable :D
I'll have mine by tomorrow so keep us up to date with results and bios settings when possible. :up:
Leeg can you post NB, PLL etc. voltages for 500FSB Performance level 8 with ram at 1200Mhz?
So far it has been interesting.
I was able to hit 8x450FSB using 2x1GB 5-5-5-15-3-25 PL7 & 400FSB Strap but was not able to keep it prime stable. The highest FSB I was able to keep stable w/ the same timings and 2 sticks was 440 but for 24/7 this is what I stuck with:
I there a pencil mod for Vcore on this board? With Loadline Disabled there's a ~.08V difference between Idle and Load. I would like to shoot for 9x425MHz but it would take >1.4V for me to do it w/ LLC disabled. It would be nice to cut the difference in half since I don't like enabling LLC, especially above 1.3V.PHP Code:JumperFree Configuration Settings
AI Overclock tuner: Manual
CPU Ratio Setting: 8.5
FSB Strap to North Bridge: 400
FSB Frequency: 425
PCI-E Frequency: 105
DRAM Frequency: 1133
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: Manual
1st Information :
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15
RAS# to RAS# Delay : 3
Row Refresh Cycle Time: 25
Write Recovery Time: 6
Read to Precharge Time: 3
2nd Information :
READ to WRITE Delay (S/D): 8
Write to Read Delay (S): 3
WRITE to READ Delay (D): 5
READ to READ Delay (S): 4
READ to READ Delay (D): 6
WRITE to WRITE Delay (S): 4
WRITE to WRITE Delay (D): 6
3rd Information :
WRITE to PRE Delay: 11
READ to PRE Delay: 5
PRE to PRE Delay: 1
ALL PRE to ACT Delay: 4
ALL PRE to REF Delay: 4
DRAM Static Read Control: Enabled
DRAM Read Training: AUTO
MEM. OC Charger: AUTO
AI Clock Twister: Strong
AI Transaction Booster: Manual
Common Performance Level 7
Pull-In of CHA PH1: DISABLED
Pull-In of CHA PH2: DISABLED
Pull-In of CHA PH3: DISABLED
Pull-In of CHA PH4: DISABLED
Pull-In of CHB PH1: DISABLED
Pull-In of CHB PH2: DISABLED
Pull-In of CHB PH3: DISABLED
Pull-In of CHB PH4: DISABLED
CPU Voltage: 1.3625V (1.28V under load)
CPU GTL Voltage Reference (0/2): AUTO
CPU GTL Voltage Reference (1/3): AUTO
CPU PLL Voltage: 1.50V
FSB Termination Voltage: 1.20V
DRAM Voltage: 2.14V
NB Voltage: 1.28V
NB GTL Reference: AUTO
SBridge Voltage: 1.10V
PCIE SATA Voltage: 1.50V
Load Line Calibration: Disabled
CPU Spread Spectrum: Disabled
CPU Clock Skew : Auto
NB Clock Skew : Auto
Advance CPU Settings
CPU Ratio Setting: Manual
CPU VID: Default
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled
Intel® Virtualization Tech: Disabled
Vanderpool Technology: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
As for 4x1GB sticks I was unable to do anything worth while. It took PL10 just to boot into windows @ a 400FSB Strap & 1066MHz using 5-5-5-15-3-42 timings but errored out of Prime w/in 3 minutes.
Can someone tell me a functional nbv range on this board w/ 4 sticks of RAM?
I'm currently testing my 2x2GB OCZ FlexII's. They seem a little more well behaved than 4x1GB Cell Shocks.
I was unable to get them to run on the 400 Strap which was the case when using them on my DFI x48 board so I am currently using the 266 Strap. I have a feeling that I will need to delve into DRAM Clock Skew if I want to reach anything close to 1066MHz.PHP Code:JumperFree Configuration Settings
CPU Ratio Setting: 7.5
FSB Strap to North Bridge: 266
FSB Frequency: 400
DRAM Frequency: 1003
1st Information :
CAS# Latency: 5
Row Refresh Cycle Time: 55
2nd Information :
3rd Information :
WRITE to PRE Delay: 14
PRE to PRE Delay: 1
ALL PRE to ACT Delay: 5
ALL PRE to REF Delay: 5
DRAM Static Read Control: AUTO
AI Clock Twister: AUTO
CPU Voltage: AUTO
DRAM Voltage: 1.94V
NB Voltage: 1.24V
CPU Clock Skew : AUTO
NB Clock Skew : AUTO
CPU VID: Default
If anyone has any tips on how to run 4x1GB sticks at a decent performance level on this board let me know.
There wasn't an option to delete the vdroop?
What is the function of Load Line Calibration??
