Originally Posted by Lastviking
CCBBE 0615DPMW. unfortunately, it's not the CCBBE 0615EPMW :(.
Originally Posted by dng
Hmm i think you doing something wrong o got 0615dpmw on a 165 i do 3.0ghz with it easy..., i have also seen more 0615 dpmw and they also do 2.9-3.0ghz
What psu do you use , what temps do you have?
Try 1.45v-1.5v and 2.85ghz
i have an antec 550W 24pin psu. i'm running at 2750Mhz with vcore at 1.45. temp is showing 46/48 that's cpu0/cpu1 respectively while orthos is running right now. while i was testing and doing burn-in last night, i notice cpu0 is always the one crashing, but the temp reported by CoreTemp shows cpu0 running by a few degrees cooler than cpu1. also, when i first installed this opty, i was able to temporarily boot into winxp at 2900Mhz. i've been trying to get back to 2800 or 2850 all day today.Quote:
i got a pair of g.skill hz 2x1024 ddr500 and here are the settings i have on this dfi lanparty ultra sli-dr:
3
4
7
3
11
14
2
2
2
3
3072
Auto
Enable
Auto
0
Lev. 8
Lev. 2
8 Nano
Normal
5 Nano
Auto.
this is going down the list and i hope you can decipher it :).
275 htt
3x
10x multi
memory is on a divider 180, i wish i could run 1:1 or 200 on these g.skill, but 270Mhz htt is the max the memories can handle. I'm thinking i might have to relax the settings some more. I really appreciate your helping me with this :). Thanks in advance.
woot
just got me a CCBBE 0616XPMW stepped 165.
from neweggs tennessee's warehouse. i have another one coming tomorrow also.
i'll post the results from this one in a bit!
im just gonna drop it in my board and hope for the best...
Originally Posted by haste
nice, are you going to keep these gems? i'd like to see the results, have fun.
CCBBE 0617 FPMW @ Opteron 170
270x10 @ voltage auto (1,3v) [ XP90 and Noiseblocker SE2 ]
RAM @ 100 (135mhz)
Orthos 24h just passed ...
http://img381.imageshack.us/img381/8...m100yo1.th.jpg
Originally Posted by Sonic9
why don't you oc it more :). 24 hours seem like overkill for me :).
or set priority to 10 :slapass:Quote:
Sure I will but I havn't thermal grease for the moment and I want to remove IHS.Quote:
I can boot windows and run many programs @ 2,9ghz with 1,35v/1,4v but orthos failed at 2/3 mins ...
core 0 is good on this 0616xpmw but core 1 is crap.
running at 2.7ghz right now at stock voltage. stressing with orthos as i type this.
i cant even get 2.9ghz from core 1 at 1.5v 8( orthos crashes immediately on core #1 when trying higher than 2.7ghz.
this is the chip i'll give to my friend. :D
he is running a PIII 933 right now, so i don't think he'll complain!
load temps on both cores within 1 degree of each other using coretemp
full load at 45c with IHS still attached w/water. only half my fans running in my system. if i turned the other half on it will drop by 5c more...
oops, double post
great chip ;) mine does 3.0 @ 1.55, but it gets too hot. i need H2O ...Quote:
A buddy and me both got CCBBE0616XPMW Optes 165s, Mine does 3006MHz at 1.47v. His wouldn't hit that till 1.57 or so and couldn't stay there for long. The difference we found out was cooling. I was on water he was on air. He installed some Peltier Hybrid unit and suddenly his chip was nearly matching mine. I think he needed 1.5v to hot 3006MHz. Our conclusion was that these things work much more efficiently with just a few degrees better cooling. This isn't supercooling at minus 30c or something, just a 10c difference will drop the Vcore below 1.5v for 3006MHz. FWIW
maybe i should pop the lid...Quote:
Originally Posted by Merc14
Originally Posted by Ivan Os
call me a noob, but what's the difference between a priority of 1 and 10? i've been running orthos on priority 1 for burn-in. Thanks.
Try to write this again on priority 10...:stick: :p:Quote:
oh hehe, i'm wrote the post on another pc :). but i do know what you mean now, priority 10 it is then. Thanks.
alright, got my 2nd 165 in today from the tennesee warehouse(newegg).
its a 0610dpmw which seems to be a good stepping.
i wont be able to test till tomorrow night or sunday though. i hope its better than my 0609fpmw!
is there something wrong with the chip in your sig ??? 2.96 @ 1.4v ! what more do you want ;)Quote:
common sense tells me that priority 1 would be better. you know, like "first priority" rather than tenth.Quote:
lol.Quote:
Originally Posted by Burnt_Ram
circumstances...
i had a 170 in my HTPC computer and sold it to a canadian dude.
im also building a computer for a friend. so, thats why i ordered 2 new 165s.
im hoping to get past the 3ghz hump and be 24/7 stable.
but, if not..i'll be happy with what i have already. 8)
i'd love to have a chip that can do 2.9Ghz or better with low vcore :). any way you can hook me up with a good stepping 165 from the warehouse haste? also, with people running their 165 in the 2.8Ghz and above, could you please show your bios settings. i'd like to see bios settings so i can hopefully get mine to run a little faster. thanks in advance.
what settings do you want to know ?Quote:
vcore: 1.45v *over voltage enabled*
HT Link: 3X
HTT: 323
multi: 9x
mem voltage 2.65v
what's your divider? i wish my g.skill can run at ddr400 speed instead of ddr360 :(.
hmm, i think my ram is running at 208mhz. my bord doesnt have divider's per say. i set a HTT then take my pic of ram frequency on the divider tab or whatever you call it. hope i mad sense ...Quote:
