Think i have seen that problem too on my deluxe, sometimes with LLC set the system will randomly reboot for no reason
470ish mate for daily ops... but I wouldn't go over 450FSB... think it's more CPU related then mobo wise , I have primed with CPU under water at 500FSB but the excessive voltages (Vcore, PLL and FSB Term voltage) my Qx needs then to be stable is not worth it for me...
http://users.pandora.be/OAP/P5QDlx/500-1200prime.jpg
I have no issues with LLC on Enabled.
Yes, I think I did.Quote:
Did you properly install all the ATI drivers mate ?
Fixed it now by first installing some Microsoft HD Audio update, then installing seperate ATI HDMI drivers. :mad:
Yup I have the -E too, and seem to be having issues with stability on it too, mainly on the memory side of things, I cant seem to get what used to be good overclocking RAM, stable, and it seems to be with both 1201 and 1103, I have reverted back to the best bios I know of to date for this board which is 1003, and amazingly, my RAM is overclocking and memtesting fine, so much for improved memory compatability in 1201 and 1103, they might of improved some in it but they seem to of lost a :banana::banana::banana::banana: load of others in the process.
Has anyone played with skews on this board at all? I find at 450fsb cpu skew 400 and 100 nb skew appear to make everything feel more efficient although I don't see anything in benchmark results. As for dram skews... has anyone touched these? From what I can understand it adjusts for the different trace path lengths in the dimms. Helpful for duel channel. Has anyone played with the yellow slot skews (1 and 3)?
oh and i'm still with bios 0803. The newer ones make my system wonky.
Everything in the code is for:
- E6600
- P5Q-Deluxe
- 1x1GB Crucial Ballistix DDR2-800 (killed a stick recently, have 2x2GB G.Skill on order)
- eVGA 8800GT
- Silverstone Olympia 650w
For the life of me, I can't get this thing stable at 3.4GHz. On my old crap DFI Inifnity 975x board, I could do 3.4GHz daily. Are my voltages too low?Code:JumperFree Configuration Settings
AI Overclock tuner: MANUAL
CPU Ratio Setting: 9
FSB Strap to North Bridge: 333
FSB Frequency: 378
PCI-E Frequency: 103 (trying 105 now)
DRAM Frequency: 757
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: MANUAL
1st Information :
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time: AUTO
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
[2nd and 3rd information for RAM is ALL AUTO]
DRAM Read Training: AUTO
MEM. OC Charger: AUTO
AI Clock Twister: AUTO
AI Transaction Booster: AUTO
CPU Voltage: 1.5
CPU GTL Voltage Reference (0/2): .695
CPU GTL Voltage Reference (1/3): .695
CPU PLL Voltage: 1.56
FSB Termination Voltage: 1.26
DRAM Voltage: 1.96
NB Voltage: 1.18
NB GTL Reference: .665
SBridge Voltage: 1.10
PCIE SATA Voltage: 1.50
Load Line Calibration: ENABLED
CPU Spread Spectrum: Disabled
CPU Clock Skew : AUTO
NB Clock Skew : AUTO
[In the 1201 BIOS, I have something here set to "Optimization"]
Advance CPU Settings
CPU VID: Default
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled
Intel® Virtualization Tech: Disabled
CPU TM Function: Enabled
Execute Disable Bit: Enabled
Hmm... maybe I missed that. I didn't write down the settings from that CPU page, just the AI Tweaker page. I tried to do that other page from memory...
I'll go back and check.
EDIT: CPUID Value Limit was DISABLED to start with.
Well I received the right chips and I still get lockups on 1201..It is a communication error between the hard drives and the board for some reason on the newer bios now but, again I was on the 1102 fine before I pushed it to hard and lost her. I trhink it might be something on my hard drives TBH. I need to talk to western digital and see what they think.
Orthos failed after 30min.
Can someone explain to me wht the GTLref and PLL voltages do? I've raised them and they've bought me extra time in Orthos but I don't know the meaning behind them.
I don't know what your settings are supposed to be but they have to do with your processor as far as I know. I have mine set to .63, .63, and 1.56 and it is rock solid but you have a .65nm so it is different I know that.
Do the Velociraptors work well with this board because honestly I am tired of Raid issues with these drives?
It is strange though, I am of the belief that a PC should be able to run anything for any length of time if it is indeed stable. If it cannot, and the software has been proven stable on may other setups, including others using the very same board, I think the hardware is at fault.
No I don't use LLC, I think droop is necessary. I have tried upping it one notch, but I will try one more, however if the cpu was causing it, wouldn't it fail small FFT rather than pass it and instead fail large FFT like it is doing?
I have to try that linpack program and see what it says. I can game for hours with no issues and the machine is stable under all circumstances except orthos large FFT (have not tried blend though, but I would assume when the FFT length approached that of Large FFT setting it would fail after awhile).
Also, I still cannot boot the ram between DDR 1200 & 1275 MHz. However I can boot at DDR 1277 all of a sudden, like it comes out of a hole. Very weird behaviour. I think my board is damaged somehow, as I have tried every bios from 610 to 1201 and all do the same thing.
Bios 1103
E8600 @ 4.6GHZ strap 333 mem 1105MHZ CellshockPC8000 CL4 = 5-5-5-15 / 5-5-5-12 2.3v best time in superpi 10.750.
I buy new mem to day G.skill PC8000 CL4 = 4-4-4-5 fast TEST 1105MHZ 4-4-4-8 2.3v superpi 10.094.:shocked:
I hope they can help me,whit 500x10 fsb an,perhaps more :D
Stability is depending on ya own preferences mate, some prefer 12 hours prime small FFT's and then afterwards large, some run an OCCT test cpu and mixed, some do superpi runs, some do benchmarks, some make a mix... if the rig is stable in daily usage and you don't experience any anomalies consider it stable for your usage... I find it absolutely waste of time and cycles to prime for such extended periods but to each his own not even considering the extra load on ya pc's components
I run the same ram kit here for testing, mine cap out at 1240mhz... sadly for you the P45 is not a SuperPi slasher... hope high FSB can do it for ya...
Does anyone know if this heatsink will fit on the P5Q Dlx?
http://www.newegg.com/Product/Produc...82E16835207004
Been thinking about upgrading to something better then the Zalman and also thinking about using a liquid metal pad...
http://www.sidewindercomputers.com/colimeforamd.html
Does anyone have any tips about this stuff? Considering the Sunbeam vs the TRUE because of this review here..
http://www.frostytech.com/top5heatsinks.cfm
I usually start compressing huge size of files with 7-zip and Orthos Mixed mode at the same time. If it doesn't fail that it'll most probably be 100% stable for everything youdo usually.
