Yes mate, pure garbage !!!!
I'm very angry about asus support.....:mad:
These are my settings, but it doesnt post with this even though they are just rated ram speeds. they are not my 24/7 settings, im just testing my ram to see how much they will oc. I use bios 0901 atm
edit: im using a i7 930 cpu.
Code:Target CPU Frequency 3003MHz
Target DRAM Frequency 2006MHz
LN2 Mode: Disabled***
QPI Loadline Calibration: Disabled***
Sync Mode [Enabled]
AI Overclock Tuner [Manual]
OC From CPU level Up [Auto]
2D Performance Booster [Disabled]
CPU Ratio Setting [21.0]
CPU Turbo Power Limit [Disabled]
>CPU Configuration----------------------------
C1E Support [Disabled]
Hardware Prefetcher [Enabled]
Adjacent Cache Line Prefetcher [Enabled]
Intel(R) Virtualization Tech [Enabled]
CPU TM Function [Disabled]
Execute Disable Bit [Enabled]
Intel(R) HT Technology [Enabled]
Active Processor Cores [All]
A20M [Disabled]
Intel(R) SpeedStep(TM) Tech [Disabled]
Performance/Watt select [Power]
Intel(R) C-STATE Tech [Disabled]
C State package limit setting [Auto]
C1 Auto Demotion [Enabled]
C3 Auto Demotion [Enabled]
BCLK Frequency [143]
PCIE Frequency [100]
DRAM Frequency [2006]
UCLK Frequency [auto]
QPI Link Data Rate [auto]
Memory Configuration Protect [Disabled]
>DRAM Timing Control--------------------------
CAS# Latency 8 [8]
RAS# to CAS# Delay 9 [9]
RAS# PRE Time 8 [8]
RAS# ACT Time 24[24]
RAS# to RAS# Delay 4 [Auto]
REF Cycle Time 72 [Auto]
WRITE Recovery Time 10 [Auto]
READ to PRE Time 6 [Auto]
FOUR ACT WIN Time 24 [Auto]
Back-To-BackCAS# Delay 0 [Auto]
Timing Mode 1N [1N]
Round Trip Latency on CHA 59 [Auto]
Round Trip Latency on CHB 61 [Auto]
Round Trip Latency on CHC 62 [Auto]
WRITE To READ Delay(DD) 8 [Auto]
WRITE To READ Delay(DR) 8 [Auto]
WRITE To READ Delay(SR) 18 [Auto]
READ To WRITE Delay(DD) 7 [Auto]
READ To WRITE Delay(DR) 7 [Auto]
READ To WRITE Delay(SR) 7 [Auto]
READ To READ Delay(DD) 7 [Auto]
READ To READ Delay(DR) 6 [Auto]
READ To READ Delay(SR) 4 [Auto]
WRITE To WRITE Delay(DD) 7 [Auto]
WRITE To WRITE Delay(DR) 7 [Auto]
WRITE To WRITE Delay(SR) 4 [Auto]
CPU Differential Amplitude [Auto]
CPU Clock Skew [Auto]
IOH Clock Skew [Auto]
------------ Extreme Engine Digi+ ------------
Digi+ PWR Mode [T-Balanced]
PWR Volt. Control [Auto]
Load-Line Calibration [Full]
CPU Voltege OCP [Enabled]
CPU PWM Frequency [Auto]
Extreme OV [Enabled]*
Extreme OC [Auto]
CPU Voltage 1.25 [1.25]
CPU PLL Voltage 1.35 [1.35150]
QPI/DRAM Core Voltage 1.40 [1.40]
DRAM Bus Voltage 1.654 [1.65625]
>DRAM REF Voltages----------------------------
DRAM DATA REF Voltage on CHA [Auto]
DRAM CTRL REF Voltage on CHA [Auto]
DRAM DATA REF Voltage on CHB [Auto]
DRAM CTRL REF Voltage on CHB [Auto]
DRAM DATA REF Voltage on CHC [Auto]
DRAM CTRL REF Voltage on CHC [Auto]
IOH Voltage 1.111 [Auto]
IOH PCIE Voltage 1.508 [Auto]
ICH Voltage 1.111 [Auto]
ICH PCIE Voltage [Auto]
*QPI Voltage OCP [Enabled]
*IOH Voltage OCP [Enabled]
*DRAM Voltage OCP [Enabled]
*QPI PWM Frequency [Auto]
*IOH PWM Frequency [Auto]
*DRAM PWM Frequency [Auto]
---------- Spread Spectrum Control -----------
CPU Spread Spectrum [Disabled]
DRAM Spread Spectrum [Disabled]
***on-board jumper dependant
I can't get iDirect to connect either. I tried using all three settings.
Has anyone else had an issue with this MB and large file copies to an external HD?
I have a WD 1TB external drive and try to copy my backup files to the external drive say 165GB at one time.
If I copy the 2 files separately, it will be ok, but when I try to copy at the same time, it will either bluescreen or hang at a random point during the copy.
I noticed that Win7 sometimes has trouble shutting down with the external drive. When using the computer during the day, it will sometimes forget that the external HD is connected and not show in "my computer".
I never had this issue with the Rampage II board.
OK. I assumed you're using Bloomfield while aiming for high RAM.
As I said to another user couple of post ago: "I think your main problem was trying to run UnCore @ 4GHz with too little voltage. Yes, 1.4 is usually too low for 4GHz UnCore. My Xeon W3540 needs 1.4125V for it."
When UCLK freq is set to Auto it will be lowest possible speed, in your case 4GHz, and it's hard to do without increasing VTT.
Be ready to go all the way up to 1.6-1.65V if you want to find out max RAM speed while using Bloomfield.
I'm sure you meant 1.45VTT ;)
He certainly does know what he's talking about. Which is why I want to ask, what would you say is a safe VTT to run on D0 Bloomfield for 24/7 use? I know Intel specs say 1.35v. Does this mean that 1.35v VTT is the safest limit to run and still have the cpu last you at least the warranty period of three years? So how much are you decreasing the life of the cpu by going over?
@turtletrax
With a build that nice it's a must for you to take your time ;). You seem to be the type that do all the necessary research and homework before getting into anything. I'm exactly the same way so I like that :up:.
Glad you're also going with Indigo Xtreme. Seems to be the best thermal solution available so I picked it up from SVC a while back. I'll be installing it tomorrow so will let you know the results :)
In my experience, it's more about watching your temps and just not using anything too extreme. Over 1.35 isn't a big deal, and you'll likely upgrade processors long before it would ever die on you.
http://www.xtremesystems.org/forums/...d.php?t=207972
No, I meant 1.66V. Bloomfield processors are much more resistant than Westmere. Considering max VCore is 1.35 and I've run 1.7, of course I'm going to push VTT too. I've only pushed it this high on dice, though. For my 24/7 VTT is at 1.48, 1.42 as measured with my DMM.
Asus support reply this:
That thing requires a driver on the PC end to allow communication with the iPhone / iPAD. I am checking with my Asus contact on the release date of the PC driver. Will come back here when I hear back from Asus
well, they release utility without Pc driver to use it.... EPIC FAIL:eek:
Hi guys, I'm looking for some help in getting my system stable.
I can load Win7 with no probs 21x215 at 1.4Vcore and 1.35uncore, but I get BSOD after 5-10mins of Prime95 (Errors 0x00000101 and 0x00000124).
I've upped the voltages up a bit, to 1.45Vcore and 1.4uncore, which I think is the highest safe for 24/7???, , temps are good 45idle and 66under load.
Here are my bios settings:
Any help would be greatly appreciated :DCode:BIOS 0901
Target CPU Frequency 4.504MHz
Target DRAM Frequency 1715MHz
LN2 Mode [Disabled]***
QPI Loadline Calibration [Enabled]***
Sync Mode [Enabled]
CPU Ratio Setting [21]
Intel(R) Virtualiyation Tech [Enabled]
CPU TM Function [Enabled]
Intel(R) HT Technology [Disabled]
A20M []
BCLK Frequency [214]
PCIE Frequency [102]
DRAM Frequency [1715]
UCLK Frequency [3432]
QPI Link Data Rate [7723]
CAS# Latency [8]
RAS# to CAS# Delay [8]
RAS# PRE Time [8]
RAS# ACT Time [24]
RAS# to RAS# Delay [Auto]
REF Cycle Time [Auto]
WRITE Recovery Time [Auto]
READ to PRE Time [Auto]
FOUR ACT WIN Time [Auto]
Back-To-BackCAS# Delay [Auto]
Timing Mode [1]
Round Trip Latency on CHA [Auto]
Round Trip Latency on CHB [Auto]
Round Trip Latency on CHC [Auto]
WRITE To READ Delay(DD) [Auto]
WRITE To READ Delay(DR) [Auto]
WRITE To READ Delay(SR) [Auto]
READ To WRITE Delay(DD) [Auto]
READ To WRITE Delay(DR) [Auto]
READ To WRITE Delay(SR) [Auto]
READ To READ Delay(DD) [Auto]
READ To READ Delay(DR) [Auto]
READ To READ Delay(SR) [Auto]
WRITE To WRITE Delay(DD) [Auto]
WRITE To WRITE Delay(DR) [Auto]
WRITE To WRITE Delay(SR) [Auto]
Digi+ PWR Mode [X-Power]
Load-Line Calibration [50%]
Extreme OV [Disabled]
Extreme OC [Auto]
CPU Voltage [1.45]
CPU PLL Voltage [1.81]
QPI/DRAM Core Voltage [1.4]
DRAM Bus Voltage [1.65]
DRAM DATA REF Voltage on CHA []
DRAM CTRL REF Voltage on CHA []
DRAM DATA REF Voltage on CHB []
DRAM CTRL REF Voltage on CHB []
DRAM DATA REF Voltage on CHC []
DRAM CTRL REF Voltage on CHC []
IOH Voltage [1.23]
IOH PCIE Voltage [1.5]
ICH Voltage [1.1]
Guys...vcore advice for 980x + R3E mobo. Now I have until now been working my way up the vcore ranges and currently have it set to 1.25v. I have set my limit at 1.35v after reading posts on the net - got 32nm 1.35v 24/7 is safe. How many people have got there vcore set to 1.4v for 24/7 use? The reason I ask this question is that the crazy OC setting to 4.0 or 4.2Ghz automatically sets the CPU to 1.4v - this would mean 1.4v is safe for long term use if the cooling is good. I am on 3.9Ghz at the moment and want to know what vcore I should limit myself at. To summarize, how many people are actually running there 980x 24/7 with 1.4v and how long have u been running it (months, weeks, etc). Really appreciate the responses;))
Intels voltage range 0.800V-1.375V Intel 980X
I've had mine up to 4.5-4.7GHz 1.45v for a few bench tests other than that it runs at 3.6GHz 1.23V 24/7, I'm a gamer and really don't need anything higher yet but I might when I add another GTX 480 for tri sli and I have a stable 4.3GHz 1.32v if needed which I ran for a few days and figured out I didn't need it, Over-clocking the cards seems to make a bigger difference right now for gaming anyhow. 825/1650/1980
For me unless I need a higher over-clock for a good purpose it's staying as low as possible.
What do you all think of BIOS 1005 so far?? Are they more stable than the previous releases and dose everything still function as it should?
Thanks for the replies everyone.
I was thinking of whether or not it would be too detrimental to run my 920 @ 4.2GHz 1.25v vCore and the GTs at 7-7-7-20-1N 2000MHz 1.35VTT for 24/7. I've concluded it's safe :up:
Too low vCore, IMO. VTT is probably more then enough for that UnCore speed, but it's not easy to run CPU @ 4.5GHz.
Good. :up: Probably best of both paths of development 100x and 00xx. 0011 and 1004 shared same BIOS template, so you could cross-load settings into each other. 1005 could be merger of two.
Thanks, will try increasing Vcore and lowering VTTQuote:
A couple of questions,
IOH Voltage, what is the safe operating limits for this? 24/7
What is the consensus regarding these 4 options, that may be beneficial to overclocking?
That is still pretty good for air, decent IMC on that chip. Anything between 3845-3849 batch code should have killer potential. I have a 3849B041 i7 920 that can do 4750 on water max and runs 4200 24/7 at 1.25v prime stable.
Yea the 384x B batches are infamous for being monster overclockers. Nice chip you have there btw ;) What's different about my chip is that it's a A batch but has crazy overclocking potential.
I need to edit my post actually, my 3949A372 runs 4.0GHz at 1.18v vCore and 4.2GHz at 1.25v vCore...very similar to your chip.
I also had a question about i7s and the individual core temps. For me I see a 5-6 degree difference sometimes between the #0 and #3 core. Is this normal? I have seen screenshots of other people's i7s and some have this pattern while some do not. At first I thought it had something to do with a component on my motherboard that was heating up a certain section of the heatsink. But I think it may just be normal right?
Yes I would consider that somewhat normal as die contact is certainly not perfect across the entire surface area, that is why some peeps here lap there sinks and the chip for better thermal contact. All chips are different as well based on where in the wafer they are cut from and binning, I have seen some strange temp readings though I do not get too excited unless it creates an issue regarding stability.
