Originally Posted by
Ghostleader
I have a theory, those Corsair are probably Samsung IC and RE donīt like Samsung at all, I have similary problem with my 2x2 Trencend, I having a hard time to get them to work with my Q9650 @ FSB 450, ram @ 1800MHz CAS 8 2N but with FSB 400, ram @ 1600MHz CAS 7 1N (even though they are dubble sided 1N seems to work) they seems to work alright.
I work with 1104 right know and I have not tried 1201 yet.
But try this setup and see if it works.
FSB Frequency: 400
CPU Ratio Setting: take your pick
CPU Clock Skew: Normal (or Delay 100ps)
NB Clock Skew: Normal
FSB Strap to North Bridge: 200
PCIE Frequency: 100
DRAM Frequency: 1600Mhz
DRAM Command Rate: 2N (can work with 1N also)
CAS# Latency:7
RAS# to CAS# Delay: 7
RAS# Pre Time: 7
RAS# ACT Time: 21
Rest of the timing is on auto
DRAM Static Read Control: disabled
DRAM Dynamic Write Control: disabled
DRAM Skew Control is all on auto
Ai Clock Twister: Strong (try moderate if strong doesnīt work)
Ai Transaction Booster: Manual
Common Performance Level: 5
All Pull-Ins are disabled
EPU II Phase Control: Auto
CPU Voltage: You know what to have for your chip
Load-Line Calibration: Enabled
CPU PLL Voltage: 1.50- 1.55
FSB Termination Voltage: 1.20 - 1.45
CPU GTLVerf (0): AUTO
CPU GTLVerf (1): -40
CPU GTLVerf (2): AUTO
CPU GTLVerf (3): -40
NB GTLVerf: +60 - +70
North Bridge Voltage: 1.40 - 1.45
DRAM Voltage: 1.70 - 1.80
NB DDRVref: AUTO
DDR3 ChannelA Vref: AUTO
DDR3 ChannelB Vref: AUTO
South Bridge 1.5 Voltage: 1.51
South Bridge 1.05 Voltage: 1.06
CPU Spread Spectrum: Disabled
