Not having a lot of luck...
@ PangingIII,
I didn't have a lot of luck with the last settings. I was able to boot into windows with all of the BIOS settings, but upone restart I would get a BIOS error and have to try something else.
I did what you suggested by changing the MCH Ref Voltages up and down. All of my settings are below. The MCH Ref was the only value I changed for each trial. The values I tested are below.
Do you think I have a chip that is just limited? Thanks again for your help, and I am also learning a great deal about the board as well.
Thanks Again,
Jason
Code:
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto
CPU Clock Ratio .......................: 9
Fine CPU Clock Ratio...................: 0.0
CPU Frequency .........................: 4.00 GHz (445X9)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control.................: [Enabled]
CPU Host Frequency (Mhz) ..............: 445
PCI Express Frequency (Mhz) ...........: Auto
C.I.A.2 ...............................: [Disabled]
Advanced Clock Control [Press Enter]
CPU Clock Drive........................: 700mV
PCI Express Clock Drive................: 700mV
CPU Clock Skew (ps)....................: 0ps
MCH Clock Skew (ps)....................: 0ps
DRAM Performance Control
Performance Enhance....................: [Turbo]
Extreme Memory Profile (X.M.P.)........: [Auto]
(G)MCH Frequency Latch.................: [333MHz]
System Memory Multiplier ..............: 2.4B
Memory Frequency (Mhz) ................: 1068
DRAM Timing Selectable ................: [Manual]
Standard Timing Control
CAS Latency Time.......................: 5
tRCD ..................................: 5
tRP'...................................: 5
tRAS...................................: 15
Advanced Timing Control
tRRD...................................: [AUTO]
tWTR...................................: [AUTO]
tWR....................................: [AUTO]
tRFC...................................: [ 56 ]
tRTP...................................: [AUTO]
Command Rate (CMD) ....................: [AUTO]
Driving Strength Profiles
Driving Strength ......................: [AUTO]
Channel A
Static tRead Value.....................: [AUTO]
tRD Phase0 Adjustment..................: [AUTO]
tRD Phase1 Adjustment..................: [AUTO]
tRD Phase2 Adjustment .................: [AUTO]
tRD Phase3 Adjustment..................: [AUTO]
Trd2rd(Different Rank).................: [AUTO]
Twr2wr(Different Rank).................: [AUTO]
Twr2rd(Different Rank).................: [AUTO]
Trd2wr(Same/Diff Rank).................: [AUTO]
Dimm1 Clock Skew Control...............: [AUTO]
Dimm2 Clock Skew Control...............: [AUTO]
DDR Write Training.....................: [Disable]
Channel B
tRD Phase0 Adjustment..................: 0 [AUTO]
tRD Phase1 Adjustment..................: 0 [AUTO]
tRD Phase2 Adjustment .................: 0 [AUTO]
tRD Phase3 Adjustment..................: 0 [AUTO]
Motherboard Voltage Control
CPU
Load-Line Calibration..................: [Enabled]
CPU Vcore..............................: 1.35V
CPU Termination........................: 1.22V
CPU PLL................................: 1.50V
CPU Reference..........................: [AUTO]
MCH/ICH
MCH Core...............................: 1.20V
MCH Reference..........................: xxxx <=== The values I entered here are as follows.
All had the same result: 0.742v, 0.752v, 0.772v, 0.732v, 0.762v
MCH/DRAM Ref...........................: [AUTO]
ICH I/O................................: 1.500V
ICH Core...............................: 1.100V
DRAM
DRAM Voltage...........................: 1.80v <-> 1.90v <===
DRAM Termination ......................: [AUTO]
Channel A Reference....................: [AUTO]
Channel B Reference ...................: [AUTO]
