Originally Posted by
derek0309hk
sorry for my bad english
that doesnt matter anyway, the bubbles seems not to be the cause
for now, my room temp should be 27~29
i am running 1.35v in bios for 4.2ghz
and running prime 95 too, 70~71 load for 4cores
idle should be 40~42
i measure the temp of the surrounding of the rad too
it is 35~36
so what i am thinking is, do the block have the ability to carry heat away?
i know fuzion v2 is a good block, but i have been using it for 1 year anyway i opened it too, it is clean.
i cant measure the temp of the coolant, so i measure the rad
i assume the temp of the cooland is about 4x, is this normal? when my cpu is running 70~71
i am thinking should i sell this fuzionv2 and get a ek extreme or extreme lt
