Help to optimize: e8500 UD3P
Hello All,
I posted a few days ago but didn't get a respose.
Here is my system:
BIOS: F9
GA-EP45-UD3P rev 1.0
E8500 E0 Stepping @ 4.105GHz 1.40625v
PC2-8800 RAM 5-5-5-15 @ 1159MHz
I am trying to optimize my O/C, but if I try to lower my vCore I get a BSOD. Below is my Template:
I idle around 35degC with an internal case temp of 24degC.
The peak I have seen is ~71ish degC during Intel BurnIn test (linpack) and only about ~64-65degC with Prime95 Small FFT.
Can you help me to get a cooler running chip?
Thanks,
-Jsunn
Code:
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 8 x ]
Fine CPU Clock Ratio............................[ + .5 ]
CPU Frequency 4.105GHz..........................[ 483x 8.5 ]
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 483 ]
PCI Express Frequency (Mhz).....................[ 100 ]
C.I.A 2 [Disabled]
******Advanced Clock Control******
CPU Clock Drive.........................[800mV]
PCI Express Clock Drive.................[900mV]
CPU Clock Skew..........................[400ps]
MCH Clock Skew..........................[300ps]
******DRAM Performance Control******
Performance Enhance.............................[ Standard ]
MCH Frequency Latch.............................[ 333 ]
System Memory Multipler.........................[ 2.40B ]
Memory Frequency 1066...........................[ 1159 ]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time................................[ 5 ]
tRCD............................................[ 5 ]
tRP.............................................[ 5 ]
tRAS............................................[ 15 ]
******Motherboard Voltage Control******
Load-Line Calibration...........................[ Enabled ]
CPU Vcore [ 1.25 ]......................[ 1.40625v]
CPU Termination [ 1.20 ]...................[ 1.40v ]
CPU PLL [ 1.50 ]...................[ 1.610v ]
CPU Reference [ 0.760 ]...................[ .956v ]
MCH Core [ 1.100 ]...................[ 1.360v ]
MCH Reference [ 0.760 ]...................[ 0.866v ]
MCH/DRAM Reference [ 0.900 ]..................[ 1.11v ]
ICH I/O [ 1.500 ]...................[ auto ]
ICH Core [ 1.100 ]...................[ auto ]
DRAM Voltage [ 1.800v]...................[1.900v]
DRAM Termination [0.900v]...................[auto]
Channel A Reference [0.900v]................[auto]
Channel B Reference [0.900v]................[auto]
