Hello guys- need help again.
SHORT VERSION
Any advice for avoiding cyclones using a EK Multioption 250 Advanced Rev 2 in a horizontal position and bleeding? Do you guys know if this is even possible to do for the setup in the final pic?
LONG VERSION: The misadventures of stubbornness, how I got pissed on by my reservoir, HARD
So I've been trying and trying to get my multioption 250 advanced rev 2 working in a horizontal orientation. First try had problems with the return run from GPU 2 to the res.
The problem there was that my 90 degree adapter was causing the Bitspower crystallink to leak. Funny thing (well not really so funny when the coolant was spilling all over the bottom GPU as soon as the pump was started) was that it looked solid.
See?
So I resolved to switch to parallel flow on the next attempt(mostly as a way to get some wiggle room as space is getting tight) and reorient the reservoir in and out plugs.
Second try was a complete disaster, with coolant winding up in my eye from the bottom of the res unscrewing from the tube and pressure being high from a d5. Let me tell you those things spray hard if the restriction is high enough. So my motherboard was soaked (wet really, but between the two gpus so there was no way to gain quick access with some paper towels) but nothing was plugged in so after tilting the case to get move the flood AWAY from the expensive hardware, removing the gpus, going to town with some paper towel, and using a heatgun on low from about 5 feet away (kept it moving and only used for about 15 seconds in all) I sat down to regroup. (Sorry didn't have pics of the setup during the big mishap).
I came up with a T Line and some anticyclone inserts, but the longer insert is supposed to be used on the in port I take it. They were backwards, and it was a frothy brew in there, and LOUD.
Filling the thing is a pest too, I already installed a fillport up top to be used on the normal res placement in my case, and I'm not drilling anymore holes in the case damnit. I'm not liking the idea of running tubing from the current horizontal placement of the res to the top for the handy dandy useless fillport. A small T Line will have to do.
Any advice for avoiding cyclones (have all parts that came with the 250 multioption advanced rev 2) and bleeding with a multioption in a horizontal orientation? Do you guys know if this is even possible for the setup in the final pic?
I am hoping the hardware will still be alive but the way it looks I won't find out soon. And sorry for prattling on with my misadventures, it's been troublling to say the least.
